I've worked in high temperature electronics for quite some time now. There are 125degC rated analog switches in ceramic packages which work at 177degC at least, although whether they would meet your leakage spec I can't say. We used them extensively for synchronous detection.
If your application is short term high temperature, or if you can tolerate a some failures after a few months, then try plastic SOIC versions. Many IC's work way past manufacturer ratings, with varying reliability.
