Not many specifications to review it against there. Do you have a minimum voltage that you want to measure? Eg input range 50mV to 5.0V.
An important thing to check is that the common mode input range of the opa189 only goes to within 2.5V of the positive rail so it's only going to work to around 2.5V.
