Author Topic: i call it the ultimate power supply  (Read 1791 times)
Offline EslamTopic starter
  • Country: eg
« on: July 13, 2018, 10:12:53 pm »
hello guys
my name is eslam and i've done a small project i call it the ultimate power supply
my power supply has an arduino avr328 chip inside to control the whole thing
and i control the variable voltage and current through dc-dc converter
the main power source is 2 18v 3amps connected in parallel
features
max current limit cut off
min drop voltage cut off
battery charger
buzzer alarm
dot matrix 1602 screen
it's an open source project and i think some people here maybe interested to improve it  :-DMM
here is the project video including the schematic and the PCB
Offline Ysjoelfir
Re: i call it the ultimate power supply
« Reply #1 on: July 13, 2018, 11:31:01 pm »
Since I don't have the best network connection right now I would be happy if you could share the schematic and layout in an universal form like PDF as I can't take a look at the video. Thanks!
Greetings, Kai \ Ysjoelfir
  • Country: eg
« Reply #2 on: July 14, 2018, 04:42:04 am »
sure
here is the link to schematic and board
https://drive.google.com/drive/folders/13B2LDXFtgfuueqFDiM3VOX6_jLHPJZoM?usp=sharing
and i will export pdf in same folder today :)
  • Country: eg
« Reply #3 on: July 14, 2018, 06:21:32 pm »
check out the pdf schematic and gerber files guys
i attached them here  ;)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: July 14, 2018, 08:15:56 pm »
what type of dc-dc converter you use and how you control V and I to it?
  • Country: eg
« Reply #5 on: July 15, 2018, 09:46:13 pm »
you can choose any stepdown dc-dc converter with adjustable current
don't forget to choose in range of your own power  supply and just edit the max limit in code
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: July 15, 2018, 10:59:06 pm »
Yikes, that's the biggest, ugliest, messiest, most unreadable schematic I've ever seen.  I can't make heads or
tails of it.  It looks like something a genetic algorithm evolved, yet (mostly?) manages to avoid basic electrical errors?  I don't even know how this is made... I'm impressed.
Seven Transistor Labs, LLC
The following users thanked this post: wraper, newbrain
  • Country: my
« Reply #7 on: July 15, 2018, 11:13:56 pm »
What i know is the fan's transistor is running in linear mode. According to him current is controlled in dcdc module not shown hence i dont know what the opamps are doing down there sensing low side (i guess)  shunt and outputs connecting each other. And there are unknown /redundant?  Inductors everywhere which is a cryptic mystery...
