I think there may also be an element of shipping damage. If the carton of battery cell blister packs has been dropped on one end, the cells banging together could possibly crack the seals, or the whole shipping container full may have been roasted on top of the pile transiting the tropics.
The days of self-healing bitumen mastic seals (as found in vintage dry cells) are long gone. Not that they were any better - they just leaked *through* the Zinc can!
You could *TRY* putting cells on discharge (simple resistor across them) in an environment chamber and thermally cycling them to try to get early failures, but if its quick it wont be representative of real life, so you'll need some way of monitoring them automatically. Maybe put them all standing on their negative terminals (the end with the seal for alkaline cells) on a thin strip of aluminum foil as an alarm circuit loop. When significant electrolyte escapes, it will corrode and break the foil, opening the loop and sounding the alarm.
