Author Topic: How would you connect a million+ analog pins? (Seriously)  (Read 52258 times)
Offline ballsystemlordTopic starter
« on: February 29, 2024, 03:28:38 am »
When I first started in electronics  (I'm still learning), I had high hopes of being able to fix stuff. People like Louis Rossmann would pull up PCB schematics, and fix stuff while Dave would look at a board and practically be able to tell you what everything is without a datasheet.
Then I found out that Louis purchased schematics, and Dave knows enough to identify most things, but doesn't necessarily how how they're wired up... sadness.
So, I went to look at the PCB factories to see how they tested their PCBs. They have big machines with lots of little wires that move and probe the boards. Now you can imagine that I thought that this was a really great idea, if only I could implement it. Which brings us to this post.
For some time I've been trying to figure out the basic electro-mechanical design. Recently, I finished working on it. And theoretically, it would work.
Now I'm faced with a new problem, how would I connect several million analog pins. They have to be analog, so that I can sense the resistance of the places that they are touching. I wish to probe both new and preexisting/populated PCBs. Even if I used 16pin-input muxes, I'm looking at an amount in the tens of millions of units for a PCB tester able to probe server size motherboards -- and I'd like to be able to do eATX at least.
Is my goal an impossibility? Never!
So, how would you connect a million+ analog pins?
Thanks!
« Last Edit: February 29, 2024, 04:05:35 am by ballsystemlord »
Offline CatalinaWOW
Re: How would you connect a million+ analog pins? (Seriously)
« Reply #1 on: February 29, 2024, 05:32:03 am »
The quick answer is not at the same time.  That may not be impossible, but it is impractical and un-necessary.  But there may be answers which meet your needs.
Think of crossbar arrays.  1000 rows and 1000 columns gives you your million points and while a much larger size than most crossbar arrays at least is a credibly accessible number.  Now the question is how long it takes to interrogate the fraction of those million connections that you need to do.  There will be a time constant driven by the capacitance and resistance of the wires, but it should be possible to do hundreds or more configurations per second, and each configuration can access up to 1000 unique points.  Non unique points may also be of use.  General purpose measurement instruments will struggle to make meaningful measurements at these speeds, but you can do things to get the data you need quickly.
Now comes the hard part.  1000 points per axis is at best marginally enough to sample a motherboard size PWB with modern trace sizes and spacing.  The high volume parts get a custom bed of nails made with pins placed appropriately to do the required tests.  Having to limit yourself to a configurable test configuration puts uncomfortable limits on some applications, but might be good for many things.
Offline temperance
« Reply #2 on: February 29, 2024, 09:02:00 am »
I don't really understand which problem you are trying to solve. Why do you need a million inputs?
Some species start the day by screaming their lungs out. Something which doesn't make sense at first. But as you get older it all starts to make sense.
The following users thanked this post: David Aurora, ballsystemlord
Online Haenk
« Reply #3 on: February 29, 2024, 10:21:27 am »
Test fixures do exist. Usually you have a bunch of pogo pins connecting to dedicated test points on the PCB, those are of course part of the layout and considered during construction. That's good enough.
There really is no need to test every single via etc.
If you are trying to build some "auto testing fixture", it is probably best to use a 3D printer as a basis, and just use ground and one single pogo pin and compare measurements against reference to detect faults.
Online tszaboo
« Reply #4 on: February 29, 2024, 10:27:44 am »
Each of those pogo pins need a certain amount of force to make a contact. The smaller ones need something like 100g for full actuation, they make contact at let's say 30g. For a million pogo pins, you need 30 million grams, or 30000KG placed on the PCB to make a contact.  That's 66138,679 pounds in freedom units, or 10 Tesla cybertrucks.
You design a board for each DUT, and use the minimal amount of pogo pins to make it work. Practical limit is a few hundred. Or drill holes in plexiglass or similar sheets to place the pins, and wire them by hand.
The following users thanked this post: tom66, harerod
Offline eutectique
« Reply #5 on: February 29, 2024, 11:11:15 am »
[...] little wires that move and probe the boards [...]
[...] how would I connect several million analog pins [...]
Your question contains the answer. Use two wires and move them as necessary. Problem solved!
Offline Psi
« Reply #6 on: February 29, 2024, 11:38:35 am »
The search term for the kind that have a small number of probes that move is "flying probe tester"
It's WAY more practical to test this way, rather than having an array of a million separate probes 0.2mm apart that come down everywhere and map out the board connections.
Online mikerj
« Reply #7 on: February 29, 2024, 12:22:08 pm »
You expected what?  That Louis drew his own schematics or used illegally downloaded versions?  That Dave could glance at a PCB and instinctively know how every single component is wired together?  This, and your million pin question suggest you have deeply unrealistic expectations.
« Reply #8 on: February 29, 2024, 01:37:46 pm »
Actually, I wasn't sure how Dave did it. I thought maybe companies still produced schematics for laptop board repair in Louis's case -- but sadly that couldn't be farther from the truth.
« Reply #9 on: February 29, 2024, 01:39:49 pm »
Point taken!
I thought I'd use wires that were carefully aligned at fixed intervals and just use gravity to apply pressure for contact. No need for pogo pins.
« Reply #10 on: February 29, 2024, 01:42:19 pm »
Connection spacing. A normal MB would have, as others have said, a dedicated test fixture. Mine being generic, I'd have to assume the minimum spacing between components, via-s, and traces in my test jig's design.
EDIT: Because it's possible to accidentally place my test jig down just off of every single trace/via, I actually have to use at least 2x the expected board density for my test jig.
« Last Edit: February 29, 2024, 01:49:36 pm by ballsystemlord »
« Reply #11 on: February 29, 2024, 01:54:39 pm »
To find faults to ground, that would work fine, but the point of my tester was to find out the PCBs schematic *and* detect faults, such as open/short/high/low resistance at the same time. Granted, I'd have to still comb over the board (assuming I didn't design it; and I do intend to design PCBs eventually), to discover, based on the data I got, what's supposed to be shorted to ground, open, and have high/low resistance.
Offline Ian.M
« Reply #12 on: February 29, 2024, 01:58:03 pm »
Point taken!
It doesn't and cant work that way.  No PCB is absolutely flat as they warp during construction due to the differential expansion of copper and FR4.  A well balanced layout and good process control minimises warpage so the board is flat enough for assembly, but it certainly wont be optically flat.   Therefore if you put it on a flat array of unsprung contacts without a lot of even clamping pressure sufficient to force the board into full surface contact, at best you'll get only a few in contact, maybe a line near one edge and a blob somewhere distant, but possibly you'll only get three points of contact.  Also you need sufficient contact pressure to break through any film of oxides or contaminants that may be present, which multiplied by one million will be a very large force.
« Last Edit: February 29, 2024, 02:33:11 pm by Ian.M »
Offline Leuams
« Reply #13 on: February 29, 2024, 02:10:55 pm »
If this is for reverse engineering purposes there are methods using much less equipment and can be done with a camera. Like Dave does you look at the ICs used and either look up the datasheet or already know it's pin out and from there it is easy to intuit the connections. What you can't figure out a DMM is cheaper and easier then 1M probes.
Offline CaptDon
  • Country: is
« Reply #14 on: February 29, 2024, 02:22:49 pm »
Everyone in the business knows the answer is in some cases 'flying probe' and in other cases 'pogo pins' and perhaps a combination of both. Your 1 million analog inputs is 1 million percent bullocks!! There is no practical way to test in that fashion. What are you going to do, put a voltage on one pin and then scan the other million for correct AND incorrect continuity? Indeed, lets test a million times a million, you got a millenium to see the result of one board tested? Now here's the part you probably really missed.....Boards such as the ones you propose to test are probably 8 layer minimum with BGA style devices who's pins can't be accessed when testing final assemblies AND 80% of the traces and vias to be tested will be subterrainian and can't be accessed ever. B.T.W., even pogo pins carefully implemented suck ass. About 90% of the boards that fail 'first test' will pass if lifted off the pins and then put back down and we use all sorts of weird clamping mechanisms to try to reduce first test failures but it still happens with the best care in test fixture design.
Offline CaptDon
  • Country: is
« Reply #15 on: February 29, 2024, 02:31:25 pm »
And a funny thought B.T.W., my best test engineers knew exactly 'where to press down on the board' to make it pass the test on a second try if it failed on the first try. We had hords of DITMCO testing units in the QC / QA lab. I can tell you the story of the origin of DITMCO in testing Drive-In-Theater speakers out on the posts which could number into the hundreds at any particular Drive-In.
Online tszaboo
« Reply #16 on: February 29, 2024, 03:39:56 pm »
I would rather try to modify/hack a 3d printer to probe a PCB at given intervals. It's a fun experiment, and you can learn a lot doing it.
Offline temperance
« Reply #17 on: February 29, 2024, 04:15:30 pm »
Reverse engineering the PCB...
Finding the connections is only a small part of what you will need. How will you find the part numbers? A lot of QFN packages have markings which you might be able to find with a lot of luck if you happen to know what that component it might be. Laptops, motherboards,... often contain custom components which you will not be able to find.
What you are trying to solve is a problem on your own side. It might help you more to learn basic circuit knowledge and troubleshooting skills.
Let's say a touchscreen doesn't work. If you know the type of touch screen and how those work is often enough to locate a problem. The real problem is getting the part in question. The touch screen itself might be fine to obtain. But obtaining the touchscreen controller will be an other story.
« Last Edit: February 29, 2024, 04:37:59 pm by temperance »
Offline amyk
« Reply #18 on: March 01, 2024, 03:21:09 am »
The reversing/cloning companies, most of them in China, already have automated flying probe testers, but they only work once all the components are removed from the board.
Offline Doctorandus_P
« Reply #19 on: March 01, 2024, 11:45:27 am »
"A million pins" is doable, but also expensive.
A brainless approach is to use 250k units of my Siglent SDS1104X-E 100MHz scope and then wire them together in a LAN. It would be a building full of oscilloscopes, so maybe you want to go a bit more compact. For example, this: https://www.ni.com/nl-nl/shop/model/pxie-4300.html is a 16 channel PXI module and there are lots of similar modules in different resolutions, channels, bandwith, etc. Pickering makes high channel count multiplexer modules for PXI buses.
Also, if you're going to buy a system of this size then a manufacturer will be very happy to design custom hardware according to your specifications. (For example an extra sync input).
Also: Make a quick calculation of the cost and size of such a setup. This will learn you that such a system is:
* Nearly always cost prohibitive.
* Needs a budget that easily allows for custom design.
* Makes custom design (bandwith, resolution, accuracy, etc) mandatory to keep costs somewhat reasonable.
Depending on the specifications, accuracy bandwidth, etc, it can also be relatively easy to DIY for an "affordable" cost. An affordable system is likely to consist of microcontroller based modules that each handle a number of inputs, and are then networked together (RS485, CAN, Ethernet, etc). RS485 and CAN would need a lot of extra (de) multiplexing. With Ethernet you can use standard routers (127.x.x.x has 24 bit = 4M address range) But even with 10GBps Ethernet (on the back bone) the bandwidth for each channel would still be limited to 10kbit/s per channel. But there is also https://en.wikipedia.org/wiki/100_Gigabit_Ethernet.
You can also have a look at the custom hardware that CERN has built. They have a many channel setup that produces bursts of Peta bytes per second and have FPGA based systems to discard nearly all of the generated data and filter out the interesting bits to be saved.
So I think the overall picture should be clear from this. You start with a list of requirements (voltage ranges, resolution, bandwidth, budget, etc) and from there you divide the system into modules. And if you find a solution that fits within your budget, then you can proceed with the actual design / setup.
« Reply #20 on: March 01, 2024, 06:30:34 pm »
Some men dream of having a building full of women, I dream of having a building full of oscilloscopes!  ;D
... so maybe you want to go a bit more compact. For example, this: https://www.ni.com/nl-nl/shop/model/pxie-4300.html is a 16 channel PXI module and there are lots of similar modules in different resolutions, channels, bandwith, etc. Pickering makes high channel count multiplexer modules for PXI buses.
Well, it depends on what you want to do and how fast you want it done. I'm not really going for a full on debugging and reverse engineering machine, more of a general jack-of-all-trades, but master-of-none machine.
As you point out, I'd need an oscilloscope based machine for a fully fledged debugging machine, and, as I'm aware, resistance is only 1/3rd of the parameters you could observe of non-semiconductor components. And that's without taking into account diodes, variable resistors, and any other oddities. And once you take into account semiconductors, you'd have to desoldering everything just to get started on an analysis...
Yes, I know.
If you'd like, I'll post more details in this forum, under another thread (because this will take a while), as I go along.
Link! Link! A few years ago, I tried to learn about what CERN was doing, computer HW wise, but got nothing more than the most basic of overviews! Ugh!
I'm going to start with design, move on to a miniature, to provide proof of concept/design, and then go for building the real thing.
Offline MarkT
« Reply #21 on: March 01, 2024, 09:31:35 pm »
An important property of a flying probe machine is it only adds parasitic loads to the actual pads it tests - a million probe tester would create enormous parasitics on every part of the circuit leading to malfunction in many cases.
The following users thanked this post: tooki, shakalnokturn
Offline Ian.M
« Reply #22 on: March 01, 2024, 09:58:01 pm »
The only way a million probe machine could work* would be to have some sort of mechanism to move individual probes up or down to control which make contact.  By minimising the number of probes in contact, this would reduce both the parasitics and the total force on the PCB.
* For some value of 'work' that includes being able to make multiple reliable contacts with the PCB without introducing excessive parasitics.  Doing something useful with those connections is a whole other problem.
Offline ArdWar
  • Country: sc
« Reply #23 on: March 01, 2024, 11:09:34 pm »
You guys arguing about Z-axis while here I am wondering if it even work in XY-axis. PCB designs don't necessarily follow certain pattern and pads/vias aren't necessarily falls on a specific grid locations. Component rotation aren't even always in neat cardinal angles.
I honestly struggle why do you "need" such contraptions to begin with. For reverse engineering you certainly only probing around a single (or a couple at max) PCB of which a human hand operated probe is almost always more efficient. For maybe a hundred PCB in a fab QC you may need flying probes. Only maybe a fabs with ten thousands PCBs a day throughput that warrant a custom made bed of nails.
« Reply #24 on: March 02, 2024, 02:31:34 am »
"With lower speed digital, lower frequency analog, or purely DC circuit boards, parasitics are often ignored because they do not have an appreciable impact on the functionality of these devices." -- https://resources.pcb.cadence.com/blog/2019-how-parasitic-capacitance-and-inductance-affect-your-signals
IDK what everyone thinks I'm planning on doing here, but the PCBs I use this tester on will *not* be powered up. Populated maybe, power up, no. I will be using DC signals to measure DC resistance. IDK, if scanning the PCB really quickly might create a problem with parasitics. To the best of my knowledge, the worst that my probes will be is an antenna. There are ways to shield electronics to prevent that from being a problem if those probes conduct too much signal.
You guys arguing about Z-axis while here I am wondering if it even work in XY-axis. PCB designs don't necessarily follow a certain pattern and pads/vias aren't necessarily on specific grid locations. Component rotation doesn't even always occur in neat cardinal angles. (Sorry for fixing your grammar, I couldn't help myself. :) )
I already said that I'd need to have the probes spaced 2x as dense as the minimum pad sizing, hence the need for so many probes.
I honestly struggle why do you "need" such contraptions to begin with. For reverse engineering you certainly only need to probe around a single (or a couple at max) PCB points of which a human hand operated probe is almost always more efficient. For maybe a hundred PCBs in a fab QC pass you may need flying probes. Only maybe a fab with ten thousands of PCBs a day throughput would warrant a custom made bed of nails.
Granted, at the time I was using a cheap DMM I got as a present, but it typically takes me hours to probe a sufficient amount of a PCB to create a circuit schematic to do a repair. Now it could be faster if I memorized a lot of common layouts for circuits. Then I could basically guess where things went to instead of having to chose a blind approach.
As for PCB fabs, I do hope to be able to fab my own PCBs some day. So I intend to use this invention to probe said PCBs when I am able to make them. I'm currently a bit stuck on finding sources for wafer boards and the photoresist. I have no idea who the suppliers are, much less how to get them to sell, either directly or indirectly, to me.
Thanks
Offline shakalnokturn
« Reply #25 on: March 02, 2024, 02:53:59 am »
Just for clarification, this is for analysis of fully assembled PCB's or unpopulated boards?
« Reply #26 on: March 03, 2024, 11:25:28 pm »
I intend to use it on both populated (unpowered) and unpopulated boards.
Just to be clear, I know my tester will not work on populated BGA pads.
Online tszaboo
« Reply #27 on: March 04, 2024, 09:56:27 am »
Your tester wouldn't work. Even if you can design it, you wouldn't be able to pay for it.
« Reply #28 on: March 04, 2024, 09:58:36 pm »
The project sounds totally unrealistic, I'm curious to hear how it works out if OP is stubborn enough...
Thermal camera's can tell you quite a bit for diagnosis, that and this topic got me thinking that it would be nice to have a tool that allows non-contact imaging of voltage levels on a powered PCB ;D
« Reply #29 on: March 05, 2024, 02:56:47 am »
Maybe if I'm both stubborn and insane enough, I'll try it.  :-DD
Offline donlisms
« Reply #30 on: March 05, 2024, 03:10:29 am »
"Arrogance is the goa'uld's greatest weakness."
The following users thanked this post: ballsystemlord
Offline ejeffrey
« Reply #31 on: March 05, 2024, 04:13:55 am »
Try making a mock up that is a  3x3 or 5x5 array of probes of the type and pitch you want.  You don't need to worry about the scanning yet, just add individual wires to each pin.  You can use some Teflon insulated blue wire.  See if you can get them to make contact they way you expect.  See how much force you need to apply and multiply by 100,000.
Online inse
« Reply #32 on: March 05, 2024, 04:40:05 am »
How is this supposed to work anyhow?
Am I too stupid to imagine how a fixed array of contact needles is supposed to make any sensible contacting?
If a single contact only cost you 10ct…?
Look at the flying probe video linked earlier and then explain to me, please.
Furthermore how do you think to achieve the programming and control of the measurement equipment?
Why not start with something easier for the beginning like a computer made from TTL chips with dedicated programming language and OS?
I feel trolled
« Last Edit: March 05, 2024, 05:09:56 am by inse »
The following users thanked this post: shakalnokturn
Offline tooki
« Reply #33 on: March 08, 2024, 03:47:28 pm »
CERN projects are huge collaborative efforts by numerous collaborating universities and institutions. So a lot of the documentation is similarly dispersed. A lot is found in research papers. (CERN is famously the source of a research paper with a record-breaking thousands of listed authors.) A lot isn’t publicly available.
The CERN website has documentation which has links to more detailed documentation, e.g. https://cms.cern/detector/triggering-and-data-acquisition . Most of the info is out there, if you hone your research skills and have access to academic journals.
(My old boss is working on PCBs for the next-generation CMS detector for the LHC. That’s a heck of a thing, since it’s extreme data rates, in very small spaces where you can’t use thick wiring, in radiation. So both circuit design and materials selections are interesting challenges.)
Fun fact I can gloat about: There are actually boards in use at CERN that I laid out (and many of which I assembled).
Offline coppercone2
« Reply #34 on: March 28, 2024, 06:48:11 am »
this sounds like what replicators do on a ha-tak
Offline tinfever
  • I like to make life harder for myself
« Reply #35 on: March 28, 2024, 09:49:20 pm »
If the goal is to have an automated system to reverse engineer PCBs, that's certainly an interesting and challenging problem.
I think trying to probe the entire thing at once is a non-starter. You'd have to built a custom jig with thousands of extremely precisely placed pogo pins for every unique board you want to probe. This alone would probably make it not cost effective in money or labor.
That brings you to a flying probe machine, that can probe selected points on a board very quickly. How many pads are on a motherboard? I'm guessing at least 5000 easily. If you want to check resistance between each pad and the other 4999 pads, that's something like 5000*5000 = 25 million measurements. Let's cut that in half since there will be many duplicates from ground pins and others, and you don't need to duplicate measurements on already measured nets. So 12.5 million measurements. Let's say a flying probe machine can do 10 measurements per second. This means it will take 14.5 days to probe out an entire board. That's a long time but at least it isn't years. Although if you double the number of pads on the board, the time will quadruple.
If you applied some intelligence to the probing strategy, you could probably reduce the measurement count somewhat. (CPU socket usually has many traces going to DRAM channels and PCIe channels. Check GND and power nets first using known ATX power connector pinouts.)
You'd also need some very fancy computer vision to let a flying probe machine know where to probe just from a picture of a board. Also, the board would probably need to be stripped of all components for probing. A mechanical process like this will always be more error prone than something without moving parts.
It might be easier to strip all the components off the board, get a high-resolution CT scan of it, and then design some very sophisticated software to analyze the copper connections and generate the PCB net list from that. As a bonus, you could probably take it a step further and have your fancy software recreate the PCB in gerber format or other PCB software.
If you want to get on the AI hype-train, then you could design and train an AI model to convert the net lists into schematics. The output wouldn't be perfect, but it would be much faster than manually laying out a schematic from a netlist of thousands of components.
Identifying the components on the board is another problem as others mentioned.
If you haven't done any of this before, I would consider that it might take years to accomplish this. Is it worth it?
« Last Edit: March 28, 2024, 11:02:58 pm by tinfever »
Offline CatalinaWOW
« Reply #36 on: March 28, 2024, 10:11:01 pm »
An approach which I am pretty sure has been used by those who do such things is the mechanically tomograph the boards.  That is glue, clamp, or vacuum the board down to a flat surface.  Photograph.  Grind a small amount off the surface.  Return to step one and repeat as required.  Then follow the traces through the photographs.  Variations to speed up might include not flat grinding but adjusting to follow the observed surfaces of the board layer.  In some cases I believe they even apply this technique to the semiconductors, maybe substituting etching for some of the grinding.
I am sure that the actual process is much more difficult than the simple description above.
As with all of these techniques you have to really, really want to reverse engineer the board to make it worth the effort.
Online tszaboo
« Reply #37 on: March 30, 2024, 09:43:57 pm »
Why? You can just xray boards to get the layout.
Offline coppercone2
« Reply #38 on: March 30, 2024, 09:59:44 pm »
I bet it gets confusing on a 64 layer board to try to x-ray without ultra premiuim equipment. Instead of using a carbide fly cutter or something at 0.0005 increment, if fly cutters work that low
Actually that might be a really simple and cheap operation on a good mill with the board glued down and leveled (thin superglue in a press)
Or perhaps just a silicon carbide or diamond wheel surface grinder.
Put a camera on the wheel and photo every pass
THe main problem is that you need a very sharp wheel, so you don't smear epoxy. So possibly there is 2 things that you can do
1) frequently dress the wheel *use SiC
2) freeze the PCB in nitrogen to discourage smearing
3) heavy flood water (cooled to 2C)
4) maybe a CBN or diamond wheel (need to try to determine what happens obviously, this is based on theory. I am not leaning towards surface grinders because I fuking hate dust)
5) strong suspicious that the ways and mechanisms of a surface grinder machine might be trashed by fiberglass dust. If you talk to a manual machinist about FR4 material, its like asking for weapons grade uranium. Toxicish materials (i.e. bakelite)? No problem. Circuit (glass) board? OMGWTFBBQ (I am suspicious that this means they have to take apart the machine afterwards). I have a FR4 based part I use, I Feel like the bad man when I had to get that made. I bet if he had his way there would be a duplicate machine shop outside under a tree, for use with fiberglass parts, replaced every quarter (don't bother making a roof it goes strait to the smelt recycler)
I would recommend investing in the x-ray if you can, because its the lung healthy choice. I bet you absolutely nothing good will come from grinding circuit boards, and you might be cursing yourself in a few decades about why you did not leave the stone age. Nibblers are so nice.
BTW the trick for simple boards (maybe 4 layers) to help you out but not guaranteed at low budget
1) get a  bright flashlight that can focus good (LED)
2) shine bright flashlight on PCB bottom
3) look at the traces show up
« Last Edit: March 30, 2024, 10:21:07 pm by coppercone2 »
Offline CatalinaWOW
« Reply #39 on: March 30, 2024, 11:40:43 pm »
Any method is confusing on a complex board.  I know I get confused on a 2 layer board that has relatively few covered traces.  The bigger boards require a great deal of patience, use of various methods and correlating the results and head scratching about intended purpose and so on.  You can imagine that at least some of the makers of these boards are trying to hide something and will take steps to up the complexity.  Things like aligning paths on different layers for example will complicate X-ray examination forcing either multi-angle exposures (along with trying to keep track of information across exposures).  I am sure things like this are child's play for the advanced players in these games, and have really no idea how the big boys play the game.
Grinding circuit cards is messy and potentially hazardous, but remember that automobiles grind rubber and hydrocarbons together mixed with a heady topping of trash, fluid leaks, animal droppings and Lord knows what else and sends the results into the air in quantities several orders of magnitude above any board grinding any of us will do.  Put an exhaust fan on your shop, with a filter to make nice with the neighbors, drink a beer and chill.
Offline coppercone2
« Reply #40 on: March 31, 2024, 12:37:28 am »
bad circuit designers do this because hiding crap generally reduces reliability, repair ability (for the advanced people to fix internal traces) and also has poor EM and thermal behavior, IMO decreasing the quality of the product. Even things like copper concentrations causing board stress during reflow and shit like that
Interesting how one fried internal trace can take out 20 more if someone is trying to hide something instead of having it burn out in a isolated area where it can be fixed. hello landfill
and the most likely reality is that the reverse engineering shop charged a slightly bigger NRE (say 15%) because of all the obsfuration efforts making the design take longer to map, and the reputation of the original product has a chance to go down because they started playing camouflage. Then its entirely feasible for the Chinese clone to be better then your design because they fixed the problem caused by your counter engineering efforts lol!
« Last Edit: March 31, 2024, 12:42:47 am by coppercone2 »
Offline tooki
« Reply #41 on: March 31, 2024, 09:10:40 am »
Cars aren’t fine-grinding glass. PCBs are fiberglass and epoxy, and inhaling ground glass leads to silicosis, a serious condition. This has to be taken seriously, especially when talking about prolonged grinding.
Offline tooki
« Reply #42 on: March 31, 2024, 09:12:21 am »
I very, very much doubt that obfuscation is even considered when laying out PCBs. Multilayer boards offer more than enough inherent complexity, especially when laid out quickly.
Offline coppercone2
« Reply #43 on: March 31, 2024, 09:17:21 am »
and whatever cars make is done outside in very small amounts so it gets diluted by alot. The best way to see is to get a powerful flashlight (or better yet a lazer, if you don't have OSHA) and see the air quality when you are working. It surprisingly hard to keep clean. Enough that experienced people in industry do not like doing it. Unless its some psychos at a boat shop lol
Offline CatalinaWOW
« Reply #44 on: March 31, 2024, 03:05:35 pm »
Actually cars are.  More in some areas than others.  Recycled glass is widely used in asphalt.  Concrete dust is also nasty to breath.
I do agree about dilution.  Which is why I am not too concerned about grinding an occasional board.  Silicosis is lifetime dose, so an occasional board, particularly if done with at least moderate precautions isn't likely to put you on oxygen tanks.  Different answer if you try doing this as a profession.
Online tszaboo
« Reply #45 on: March 31, 2024, 04:07:24 pm »
Nobody who uses 64 layer boards will be reverse engineering someone else's work. Even at 8-12 layers the software will be orders of magnitude more complicated than the PCB and it wouldn't be worth the effort. Besides for most PCBs any competent engineer can draw a block diagram just by looking at a board. And then what, copy the exact layout of DDR memories or PCI-e lanes? A parallel backplane? Why?
« Last Edit: March 31, 2024, 04:13:47 pm by tszaboo »
