Hi!
Can anyone suggest, for completeness, a method of finding out the maker/type number of a ferrite bead that looks physically like an SMB package diode?
Is measurement of physical size the only convenient way?
They're used in a power supply in series with fast–recovery SOD–80 diode rectifiers, and needless to say, totally devoid of markings!
Unfortunately I'm not an EMC or RF design expert and I'm bemused at the sheer number of these things in different packages, types, impedances, etc., etc.,
The two I found that most closely matched the things I had were:–
https://uk.rs-online.com/mobile/p/ferrite-beads/4673494/or the Fastron SMB/001–999X–01
I've worked out a suitable circuit–symbol to document them with, but even I can't identify the exact type originally fitted it would be nice to suggest the most likely candidate on a circuit–diagram!
Chris Williams
