Author Topic: PCB Layout/DAC build  (Read 796 times)
Offline EJCTopic starter
« on: December 02, 2023, 08:26:17 pm »
Hi Everyone!!!
New here, just hoping to get a bit of advice/criticism.  I'm doing an "upgrade" of a device used by a professor at my local university.  It is a design from the late 80's/early 90's that I am adding a micro-controller to eliminate the old parallel port input and 555 timer sequencer.  Keeping everything else in the design as close to the original as possible.  I've built a few of these on proto-boards etc so the design works, but I'd like to make a surface mount PCB.  I chose the parts/footprints mostly by what was available on JLCPCB as I want to have this built.  I'm brand new to PCB design/layout so I was hoping to get some criticism on this design.  I tried to separate the digital/analogue grounds to only meet at the power input if that makes sense.  I attached the print with the original schematic, and my kicad files.  Any advice would be welcomed and appreciated!!
Thanks,
John
Offline liaifat85
  • Country: bd
Re: PCB Layout/DAC build
« Reply #1 on: December 04, 2023, 10:33:01 am »
If your design is free of DRC errors, I think you can proceed to print the prototype.
The following users thanked this post: EJC
