Hi All
First a question: Did you settle on a final value of resistance (10.50k ~ 10.60k) for the OVP ?
If I understand it correct, the OVP resistance (10.50k ~ 10.60k) should work for all voltages ( 12.66V - 100.1k~103.5k to 15.50V - 10.68k ) right ?
Next: I'm in the process of building a 24 Volt power supply, two HSTNS-PD43 in series. Therefore one of them needs to be floated (low voltage ground disconnected from cage ground)
Its pretty easy to float the HSTNS-PD43, you don't even have to open the PSU to do it (as I did, to find out how simple it is)
First you have to bend out the little tab (red circle) 45 deg. should do it, then remove the screw (green circle) from the bottom, closest to the tab you just bent out.
Now the PCB should be able to move a little up and down at that end.
Now you need a M3 plastic/nylon bolt (approx. 1 – 1,5mm longer than original screw) and an isolating washer, I used 0,4mm mylar for the job. It needs to be a thin and sturdy, isolating material.
You need a tight fitting hole around the M3 bolt, due to a small protrusion around the hole on the standoff on the PCB.
The most tricky part is to get the washer in place between the case and PCB, but when its in position put the nylon bolt in and tighten, DONE !
Your PSU is now floated and can be used as the second, third.... or how many you want to stack in your final setup.
Now, a little insight as to why the washer has to be tight fitting and sturdy.
First when I took the PSU apart I expected I needed to isolate the PCB in 3 places (red rings in pic) but actually the PCB is only grounded in one spot (yellow rings)
The little protrusion I mentioned earlier is only 0,7mm high and 4mm in diameter with a M3 hole in the middle, that leaves us with a 0,5mm wide protrusion that the isolating washer has to "ride on" and stay on, hence the tight fit mentioned.
Hope this makes it a little easier if you have to float your HSTNS-PD43
