Author Topic: Fun with resistors  (Read 28585 times)
Offline Zero999
  • 0999
Re: Fun with resistors
« Reply #75 on: September 12, 2015, 08:56:29 pm »
I haven't installed/used the software yet.
There's an error in the PDF file posted. It talks about Rsum being the load presented to the source on an inverting and non-inverting amplifier which isn't true. With the inverting amplifier, the input resistor determines the load seen by the source and the feedback resistor, the load seen by the op-amp's output stage in parallel with the load. With the non-inverting amplifier Rsum determines the load connected the op-amp's output stage, in parallel with the load.
