Author Topic: HSTNS-PL41 Looking for info explaining How to increase output voltage 13.5v-14v?  (Read 132 times)
Offline Crunch69Topic starter
HSTNS-PL41 Looking for information to hack the power supply to produce a higher voltage than stock.  This power supply has no pot's so it will need I believe a resistor placed on an op-amp to fool the supply to increase the higher output voltage.  It may also require an override for the over voltage protection circuit OVP.
Any help will be appreciated
« Last Edit: March 13, 2024, 08:44:44 pm by Crunch69 »
