After designing a 433MHz 'basic' network for home automation, I looked at the spectrum and there were indeed *many* transmissions flying about on this band. However, things like wireless doorbells, car alarms, weather stations etc.. are all rather low duty - from 2-3 bursts a day, to every coupe of minutes, certainly not something that would kill a link for hours at a time unless your kit juts so happened to transmit at exactly the same time as the interference (so unlikely, not really worth bothering with).
So it looks like its either:
- a continuous interference - not necessarily an active 433Mhz transmission, could also be EMI generated from something else,
- the antennas of your systems are poorly placed.. or.. just-so-happen to be in dead spots.
- your equipment is faulty.
After reading the thread is seems like that the 3rd option is unlikely. And I'm sure you would have eliminated the second by moving things about (especially in the case of a garage door opener, side step and chances are if it was multipath, it would work fine).
So whilst I've just come back to what you suggested in your first post, best to eliminate other things first!
As suggested, the only real way is to 'see' the band with an SDR. This will also be able to show if its a bonafide 433Mhz transmission, or random noise something is kicking out across this band.
It would have to be a particularly powerful signal to interfere for long periods of time, most likely that is because the source is close to you.
