If you're going for cheap, as was suggested look into heater appliances, kettles, immersion water heaters, electric water heater elements, that sort of thing. They are generally pretty rugged. Also, they are by definition easy to get heat out of, especially things like electric water heater elements.
The benefits of light bulb is low cost and compact size (instead of power resistors)
Well, yeah, but you still have to deal with 800W of heat. Only a VERY small portion will end up being light, the rest is heat. The same goes for any kind of load. 800W is a LOT of heat to deal with.
