Author Topic: 'HV' switches voltage ratings: AC vs. DC  (Read 1332 times)
Offline TinkeringSteveTopic starter
« on: May 09, 2020, 03:33:51 pm »
For things like rotary 1->N switches, flip switches, push switches, or relays - you name it:
Their voltage ratings usually look like this:
AC: 250V
DC: 30V
While looking for switches to do the mapping between a vacuum tube measurement circuit (400V) and the tube socket(s) for tubes of arbitrary pinout, I noticed that there are no switches to be found which are rated for anywhere near such a high *DC* voltage, which would be needed here.
Now I'm not wondering anymore why some people use such a dangerous setup with a lot of banana jacks & patching cables for that...
Why is that? Because (I guess) AC makes arcing harder due to the direction changes?
*But* there are a lot of old technicians' tube testers to be seen in YT videos where roughly ordinary looking (if somewhat clunky) rotary switches are fit.
Were those actually special switches that were only made back in the age of tubes?
I am wondering because I am also wondering if the voltage a switch could be rated for would change if you lift the requirement of it switching *under load*, with stuff actually moving while the power is on.
E.g., say there is one main switch that turns the 400V on or off, and those pinout-mapping switches would never be moved while it's on.
Offline Neilm
Re: 'HV' switches voltage ratings: AC vs. DC
« Reply #1 on: May 09, 2020, 04:52:40 pm »
Your guess is correct IMO. The contact opening will draw an arc. An AC system that arc will only have certain characteristics and will extinguish in a resonably known time. A DC system the arc could be maintained and not extinguish leading to a fire risk.
Generally, the above means the contacts on the switch remain very close. Older testers have switches where the contacts move far enough apart for this not to be a hazard. Also, the required safety standards were less then.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Online Ian.M
« Reply #2 on: May 09, 2020, 06:19:03 pm »
An AC arc goes through zero current 100 (or 120) times a second.  That makes it *MUCH* easier to quench, hence the higher AC voltage rating. However for a DC rating, the switch manufacturers must allow for the possibility of an inductive load, and as you can arc weld with as little as 24V if you've got a big enough series ballast inductor, its very hard to find compact switches rated for >30V DC.
Back in the day, the rotary switch wafers were typically around double the diameter of  modern ones, so there could be far greater contact separation, and also they typically had very stiff ball detents so could guarantee rapid contact opening.
Probably the best option would be to use appropriately rated relays, and if you aren't going full retro, using a MCU with a LCD display for valve pinout selection.  If you are  going full retro, consider 'personality modules' for each valve type, built on a D connector, which if you use the first and last pins to interrupt power to a relay switching on everything else, should be very resistant to abuse including hot-plugging.
« Reply #3 on: May 10, 2020, 11:24:06 am »
Thanks for the answers.
I have no need for full retro, although my father, who'd like a tube tester also, is kinda allergic to all that computerized newfangled jazz, lol.
Myself I'm aware of e.g. the uTracer project by that Dutch professor, and its clever PSU scheme of "load a fat cap from a minimalist switching PSU and then discharge it during the measurement for the anode current, compensate for voltage drop in calculation".
So I myself would want to trace curves, not just get "replace / not replace" kinda readings.
His example materialization of the project uses... a banana plug patch board, though :D I would like to avoid that.
I was already planning to make tube selection at least supported by MCU + display.
I imagined that if relays are too expensive, I'd use rotary switches with double contacts, where the 2nd contact route has a low voltage for the MCU to track switch positions and not release the HV when, for a selected tube type, any switch position is off. The correct switch positions would be shown on the display.
Alas so far I've not seen relays with high DC rating either.
At some point I wasn't looking further because of the price, with regards to the number of relays needed.
(I don't know what can be done / what's out there, but I made pencil scribblings where I'd have C->A/B selecting relays with 1 set of contacts, 2 sets, and 4 sets, to make a 1:8 mux switch out of a minimum of 3 relays, or 4 pcs if at max 2 sets of A/B contacts are available.
For 9 such 1:N switches, that's 27 or 36 relays, quite a bunch.)
Maybe I should go on a longer term hunt for broken old gear to salvage parts from.
That "mapping function as pluggable module per tube type" idea sounds neat. For me, I only need a very small number of tube types, so far, so that might be viable. My father, IDK. I have no idea how many different pinouts there are. I shall ask. (I think he's also into almost-unobtainium early days stuff...)
Wild side note: motor-driven rotary switches would be funky, as a bunch of 1:N switches need far fewer units than relays.
Or even rotary switches which *are* e.g. a reduced-to-that-task stepper motor (8 coils 1 magnet?) - but I guess  without proper knowledge about contact materials etc., one better does not try to 3D-print some base for a switch and bolts contacts to it, to then operate it at 400+V...
Probably not even legal to operate, or at least insurance wise rather unwise, eh?
« Last Edit: May 10, 2020, 12:00:55 pm by TinkeringSteve »
« Reply #4 on: May 19, 2020, 08:10:59 pm »
Oh! One thing that got neglected and I'd almost forgotten about is this aspect:
So if the much lower DC rating of switches, relays is due to it being more difficult to extinguish arcing:
How about not creating arcs in the first place?
I.e. making sure (as best possible) that the switches will not be actuated when power is ON?
Remember, this is to form a mapping function from measurement circuit pinout to arbitrary tube pinout. Not for power switching per se.
Could I then use a higher voltage than the DC rating, which is meant with arcing in mind?
If relays are use, I guess I could also make a trigger-happy protection circuit which looks on the coil voltages of the relays - and, if during power is ON, any relay state changes, the main pwer is immediately shut OFF. Due to looking at the coil voltages, maybe this is even faster than anny mechanical part actually moving? So even then an arc would not be created, or almost.
With rotary manual switches, I guess one would need them with doubled contacts, to use one contact path with a low voltage, as a position indicator, and shut power off when a change is detected that way - although slower than in the other scenario.
Or maybe get a bit adventurous and fasten a plastic disc to the axis of the switch, and connect something there that will detect any movement - there are several way that come to mind. (optical mouse sensor IC? probably not adding much to the price of a fat rotary switch)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: May 19, 2020, 09:50:34 pm »
Arcs tend to be self-extinguishing at low currents; the point is you probably aren't going to have full current AND high DCV switching.
Which is probably dangerous for, say, switching under full current that sweep tubes can draw (amperes), but most signal tubes probably aren't drawing enough to get more than a small spark?
Definitely, if you've got it turning off during switching (or an intermittent -- AC -- signal), that will do.  Which, if you're thinking of a full curve tracer kind of thing, or even just an emissions or gm tester that's pulsed, that will do. :-+
Seven Transistor Labs, LLC
Offline filssavi
« Reply #6 on: May 19, 2020, 10:23:32 pm »
In theory if you remove the HV before operating the switch the rated voltage could be uprated, however in practice I’m not sure it is a good  idea for multiple reasons:
1) unless the switch is actually a relay with a proper interlock circuit it is impossible to actually enforce the power off before switch operation, if god forbids the switch is operated by the user (dial or rocker switch) it is basically guaranteed that sooner or later user error will occur. Also it is quite hard to document such a requirement in instruction manuals and such (they usually are not read, and even if they are people are used to ignore warnings)
2) it is quite difficult to actually say how  high you can safely go, since you are using a component in a very unsupported way
In the end if something goes wrong  and someone gets zapped or burns down his house, you will be responsible, and that is not terrific in any way you look at it
Online Ian.M
« Reply #7 on: May 19, 2020, 11:17:43 pm »
To prevent user mistakes, you'd need a cover over all the rotary switches (except possibly a low voltage start and stop button), with an interlock switch that cuts power and discharges all reservoir caps if the cover is open.  The interlock switch would probably control SSRs, MOSFETs, or other semiconductor devices to handle breaking the HV DC circuits, and discharging capacitors without any arcing.   Whether or not you also need a solenoid operated cover latch depends on how quickly you can discharge the caps.
If you can strictly prevent any switching action with power applied, even under fault conditions, switches, mechanical relays etc. should be OK for a peak DC voltage up to 1.4 x their AC voltage rating, at a DC  current equal to their AC current rating. e.g. A 250 VAC switch will have insulation adequate for  350 VDC.  However its highly unlikely to be able to contain the arc if it ever opens under load, and doing so would be a serious safety hazard.
« Last Edit: May 19, 2020, 11:24:56 pm by Ian.M »
« Reply #8 on: May 20, 2020, 06:04:10 pm »
Ah... mechanically blocking the switches during enabled HV... that's the safest and easiest solution so far, it seems. I'll think more about that.
Thanks for all the other input and warnings, I will heed them.
Online NiHaoMike
    • Facebook Page
« Reply #9 on: May 20, 2020, 07:40:23 pm »
Perhaps a simple "turn off power before changing switch settings" warning would be enough, as often seen on older welding equipment?
« Reply #10 on: May 22, 2020, 05:46:57 pm »
Ok, while I do like the simplicity of "just cover the rotary switches mechanically", my mind wanders off anyway and so... went to this:
Relays can't possibly switch without coil current being available, eh?
And there are these things called bi-stable relays. I've sometimes seen them for bearable prices in one-off offers.
So how about:
- making one coil supply rail for all relays.
- a analog watchdoggy circuit that looks whether that rail is on.
- whenever that rail is on, it does BOOM on the circuit that shuts down the HV, which can only be activated again explicitly, and with the condition that, of course, the coil rail is detected to be OFF.
So no changing of switch status is possible when HV is on.
I guess I could simulate something similar with mono-stable relays with some parallel-out latch shift register that holds the on/off status bits, and some intercepting element that does not electrically allow passing through state-changes when HV is on.
That would retain the vulnerability for the case that there is a defect, maybe one relay coil dying and going from ON to OFF state (if that is a failure mode that exists, I have no idea), or a sudden failure of the coil rail.
For that, maybe, rare / unlikely occurrence, the coil supply rail total current could be monitored, and if that current changes -> HV OFF trigger.
« Last Edit: May 22, 2020, 06:11:34 pm by TinkeringSteve »
