Erikka,
If I take that inputs J14 and J13. there is actually a capacitor, but connected to nothing because it goes to the SMA socket.
So we can measure the circuit input, which is pin 14.
This is where I don’t understand, for a P4302 I have 50 ohm (which seems right to me), for the other P4302 I 100 ohm.
The basic question is:
On a P4302 is the input impedance still at 50 ohm regardless of the attenuation choice? I think so, and it is inside the circuit that the attenuation is done. (Same, the output must always stay at 50 ohm the same way)
I’ll take it off and see.
For your information, I tested another P4302 chip . I have 40 ohms between pin 14 and the substrate (ground weight of the medium), but of course no other pin connected (ground or other)
To see
cdt
