I will experiment more when I get more time.
As promised, I did.
Set-up: HX711 module controlled by a LM4F120, data out via serial to the PC, reading CH_A and CH_B alternately.
The experiment started at room temperature. At about count 300, I put a hot iron on the chip, separated by four layers of paper towl. The iron is at least 275c and through the paper towl, it is too hot to hold onto the tip with my finger.
Put the tip on the chip - the rest of the circuit not impacted by the hot iron.
At about count 400, the paper towl had a burned mark on it and started to smoke. I took the tip off the hx711 - at that point, the hx711 was hot to the touch - 85C at least.
Throughout the whole process, the reading is uninterrupted.
The experiment stop'd at count 750.
The adc readings are then charted below.
You can calculate the ppm for both channels.
Two things surprised me:
1) the two channels are negative correlated - I kind of observed that in earlier charts but this is the most obvious. This would make using one of them as a reference to measure the other difficult.
2) the two channels have quite different tempco.
Interesting, in a bad way.
