Electronics => Projects, Designs, and Technical Stuff => Topic started by: gaminn on May 23, 2024, 11:11:59 am
Title: HY50-P/SP1 current transducer
Post by: gaminn on May 23, 2024, 11:11:59 am
I'm repairing an inverter and it has HY50-P/SP1 50A 5V single supply current transducer inside which seems to be broken as its output at 0A current is 0 V (should be 2 V according to https://www.lem.com/sites/default/files/products_datasheets/hy_10__50-p_sp1.pdf (https://www.lem.com/sites/default/files/products_datasheets/hy_10__50-p_sp1.pdf)) and the output doesn't change when current flows via primary. Anybody any idea where to buy this transducer or where to get a replacement? Unfortunately it looks like this is already discontinued part.
Title: Re: HY50-P/SP1 current transducer
Post by: moffy on May 23, 2024, 11:29:02 am
They have stock at Digikey: https://www.digikey.com.au/en/products/filter/current-sensors/525?s=N4IgTCBcDaIBYE8CsAGADiAugXyA (https://www.digikey.com.au/en/products/filter/current-sensors/525?s=N4IgTCBcDaIBYE8CsAGADiAugXyA)
Post by: gaminn on May 23, 2024, 11:31:07 am
No, unfortunately they don't have it in stock. It is probably HY50-P you see they have in stock which has different pinout and supply voltage.
Post by: moffy on May 23, 2024, 12:47:51 pm
Second times the charm, 2 in stock: https://fastron.com.au/products/hy-50-p-sp1
Post by: gaminn on May 23, 2024, 01:08:23 pm
Thanks a lot but unfortunately, I need multiple pieces and also the price is completely out of my budget.
The nearest replacement I found is pin incompatible ACS772ECB-200B, 10mV/A sensitivity. Unfortunately the zero of the output is at 2.5 V, not at 2 V as for HY50-P/SP1. So it will need an adapter and some circuitry around to have 2V zero of the output.
