Hi all.
I've just gotten back from London where I bought a nano drone at Hamley's and even after a couple of attempts I still cannot seem to successfully fly it. My clumsiness wants to point at the fact there doesn't seem to be any stabilizer on this thing — something that prevents it from oscillating up/down, at least. In fact you have to trim it first before flying it to make it "fly still" if I remember what I read on the manual. After one hour all I have done is lose a blade, the damn thing is unstable, oscillates up/down, flies in any direction and I can't control it reliably. Not that it is impossible, I've seen the steward gently land it on his hand as if he had been doing that all his life! Needless to say it hurts the ego a friggin' lot!
So after wondering a lot, now I'm puzzled as to what's in that beast. The fact that it needs to be trimmed — the 4 trimming buttons are on the remote: L(eft), R(ight), B(ackward), F(orward) — suggests that there's no micro-controller inside. I haven't torn it down yet but I could see a few SOT-23 parts, resistors, capacitors and that's about it. Inside the shell, a plastic skull that's holding the PCB (yes, the PCB, red, is the flying skeleton, clever) there is a (minuscule) LiPo battery (as per the manual), no idea what capacity though. There are 4 sub-miniature motors (~4mm diameter, ~10mm height but don't take it for granted) with blades directly attached to the shaft.
I tend to believe only the remote is accounting for the drift in the commands sent to the flying object, which must be only comprised of a 2.4GHz receiver and a few analog or PWM components, to make the circuitry downright simple.
Has anyone opened such a drone? Does my deduction make sense?
