I would recommend LM5030 for peak current mode control as it has easy to adjust slope compensation mechanism unlike that other chip where the compensating ramp is obtained by buffering the RC oscillator pin. I used it for one of the boost converters (12-440v, 500W) i was working on earlier as a replacement for UC2825, which is basically crap imho. Every time the primary current ramped up to the pulse termination threshold, uc2825 would somehow fail to maintain proper flux balance in the core resulting in squealing, screeching and what not... LM5030 was perfectly "symmetrical ", but then i figured current-fed push-pull worked better for a boost converted and haven't used it since.
Why don't you use a current sense transformer instead of sense resistors? I made my own from k2006 kaschke 10x6x4(?) ring... also why full bridge and not push-pull?..
