Author Topic: Dummy load for automatic input voltage test  (Read 1113 times)
Offline mrkevTopic starter
  • Country: cz
« on: December 28, 2018, 12:42:13 pm »
I am working on a semi industrial device (terminal with LCD and some functions) and I am having a hard time with a dummy load circuit. This device is (together with other simmilar devices) powered from a 12V - 18V supply.
In past, there was a problem with technicians, who often overloaded the supply, using weaker supplies than it was recommended. It worked fine in stand-by mode, but when several devices switched to a mode where they take more power, whole network could crash.
In reaction to that, our former designer used a simple circuit, it was basicaly a comparator and a 22R resistor. From 0 - 6V, the resistor would be engaged (peak current at about 275mA) and after passing 6V threshold, the resistor would be disengaged and the input regulator for the rest of the electronics would be enabled. That way, all our devices load the supply right at the power-up, which works suprisingly fine.
On the other hand, this circuit is "dumb", there is no logging, no error signalization. If the supply is unable to provide required power, it just doesn't work (and the resistor heats up significantly).
Because I was adding some other stuff (like input voltage sensing), I decided to change this circuit. I came up with this (the IC1 is actually a switch mode regulator):
T1 works as a current sink, when the voltage reaches the treshold of regulator (about 5V), it's disengaged by the 3V3 net rising above 0.5V. The LOAD_ON is for switching this thing on by the controller, which is useful for checking the connection to the supply.
But I am having doubts about the failure modes of this solution. The biggest one is that when IC1 is damaged, this load will be engaged. As far as I tested it, T1 can survive continuous opperation at 18V while heating up to 120°C, which could melt the plastic body of this device. There is some advantage in the temperature characteristics of voltage drop across D1 and T2, but it's not enough.
So I am not sure if I should make some fail-safe mechanism or completely abandon this solution. Any ideas?
« Last Edit: December 28, 2018, 12:46:41 pm by mrkev »
Offline ogden
  • Country: lv
Re: Dummy load for automatic input voltage test
« Reply #1 on: December 28, 2018, 01:30:47 pm »
You shall solve source of power budget planning problems, not results. Idea behind that circuit is very strange, you really shall think how to do things differently.
Are you sure it is not in-rush overcurrent at power-on problem? If you have control over behavior, thus power consumption of your end devices, try to introduce random power-on start-up delay in range like 0.1 to 1 sec so they all do not draw high current right at the power-on. After they are powered on, it is unlikely that they all will draw maximum current at the same time, right?
  • Country: cz
« Reply #2 on: December 28, 2018, 02:12:26 pm »
Solving the power budget planning problems is unfortunately impossible. Our technicians know and follow requirements, but we also use contractors and they often bodge it. I am also not sure, if I can simply omit this circuit comletely, because it has been presented as a "feature" and "one is not supposed to delete features". If it were only on me, I would use switchable dummy load that could test the power net on command.
These terminals are mounted on wall and they are basically made to be powered 24/7. The likelyhood of several units drawing maximum current at the same time is actually fairly high, since this occures when there is an human input and you can get that during rush hours.
