Author Topic: Eagle CAD print pdf generation issue  (Read 545 times)
Offline DhanushkaTopic starter
  • Country: lk
« on: June 25, 2019, 03:01:28 pm »
When I generate a pdf file in Eagle, the output is a colored image like i have attached. Please anyone can tell me that how generate a pdf file with black traces on white background for toner transfer method. Only I need to go through pdf print way.
Thank You
« Last Edit: June 26, 2019, 03:57:28 am by Dhanushka »
  • Country: lk
Re: Eagle CAD print pdf generation issue
« Reply #1 on: June 26, 2019, 04:54:37 am »
However, I solved this problem. There is a check box to select the black color in the print options.
