I am aiming at making a network addressable LED 3 watt boost converter for a couple of dollars the magic figure being 2$.
For 2$ all you are gonna get is a linear current limit. Forget about being efficient with that.
Perhaps 10-20 times as much if you want it to be 'smart'.
LED Light modules can cost from 500EUR upwards.
It is just really inefficient to have centralised fixtures. The main reason for centralised fixtures is due to old wiring infrastructure and the inability to move it round.
Why inefficient ?
10x200 lumens is the same as 2000 lumens that spread around minus the excessive wiring.
25% of your home energy usage is lighting, commercial buildings it is closer to 60%.
I have it around 2-3% for lightning. Everything else is cooking/heating/TV/PC.
In commercial buildings that percentage is high merely because all they have is lights and PC's.
LED dimming methods are 100% efficient.
Not all and not 100%.
If you want to go down the energy efficient lighting root you don't have to go solid state. There are problems here as there are some super CFL's but you can't dim them. There are versions that you can but again the cost goes up.
You are forgetting that energy efficient is not everything. Things have to be cost-efficient as well.
Ordinary fluorescents can be dimmed, pulsed dimming, same as with LED's.
Just not with ordinary dimmer - triac with some EMI filtering.
But output goes 20% down with only 5% lower voltage so dimming has to be precise. And with low power outputs there is something similar to strobe effect when you 'see' plasma moving around the tube.
However. It works and it works very well. Just look at the number of LCD panels made with cold-cathode tubes inside. Everyone of them that has adjustable brightness proves the concept works well.
However, forget about CFL's and dimming. These things are worthless even without it. Low power output on start, fast aging, dying electronics due to excessive temperatures in the fixture. 8000h rated at 50% failure rate and so on and so forth.
LEDs also loose their output over time (forget about 40k hours with power leds, perhaps 10k or not even that) and _have_ to be cooled with really big heatsinks if you want them to be passive - that adds to the cost as well.
Also pulsed dimming with led's is useful for preserving the same light temperature but does not spare the led. It is much better to step down on voltage a bit (analog dimming) and then use pulsed dimming, you gain some efficiency at lower led output and don't stress it as much.
Also. Light drops out at higher temperatures.
Converting whole electrical system to 12/24V DC would be a good idea, also, you could use power cables for data communication as well, few wires less.
