Author Topic: Load switch with Triac and Reed Switch  (Read 2473 times)
Offline PrayerTopic starter
« on: January 12, 2015, 03:30:36 pm »
Hi All
I want to make and switch to control light in cabinet. I need to switch 220 VAC with triac and reed switch. I will place a magnet to door and I will place main box across magnet. The maximum lenght is 15 cm between door and main box. I think reed switch will work properly.
You know reed switchs are normally open and when magnet is getting closer, reed switch will close. Could you help me to build schematics with NO reed switch ?
Offline mij59
Re: Load switch with Triac and Reed Switch
« Reply #1 on: January 12, 2015, 04:29:12 pm »
Why don't you use a door or limit switch ?
« Reply #2 on: January 13, 2015, 07:28:00 am »
Because already using limit switch solutions but customers have some problems to fix limit switches correctly. Customer want to use easier solution and we will make like this. Do you have any schematic suggestion ?
Offline mij59
« Reply #3 on: January 13, 2015, 07:48:31 am »
No don't have a schematic at hand, I would go for a of the shelf solution, e.g. a inductive proximity switch, infrared motion detector.
If you build a circuit it has to comply to the 220V regulations.
« Reply #4 on: January 14, 2015, 04:21:17 pm »
Is there any suggestion for this issue ?
