Is the purpose of r37 here to pull the output low when 0V input comes?
It could be the design idea but if so than in my opinion it is not good project.
According to LMV331 datasheet input bias current is typically 15nA so voltage drop at 330k is typically 5mV while max input offset is 7mV.
I would expect this working as intended only with 99,9% of ICs (so not 100%). Designing to work with 100% of ICs allows you to not select them before assembling.
As your simulation shows 8.2mV than probably your model not follows typical bias current info from datasheet. It is also possible that input current changes when inputs are driven with some offset, but I would rather expect current of input driven more negative (by r37) be smaller than typical and not higher. But as the max is specified as 250nA the model author could think it would be better to have input current higher than datasheet typical value.
May be the author of this design used someway the same model as you and selected r37 to reach higher then 7mV offset believing the Spice more that anyone should. I never use Spice to simulate anything else than simple transistor circuits and supply filters (taking into account parasitic elements in capacitors and chokes). For ICs I always just follow their datasheets.
Interesting is what will happen if input current will be 250nA (or 400nA). For 250nA we get 82mV. Don't knowing what is the input signal tested by this circuit you can't be sure if it is not too big for the circuit to still be working as expected.
I get suspicious just by seeing that the signal flow is from right to left.
You don't see the whole picture. I suppose main signal is going from left to right and this is only feedback. Imagine how OpAmp circuits would look like if you force that signal should always go from left to right (including feedback circuits).
