I am somewhat familiar with 8-Bit Guy’s dream computer: Commander 16. I've been following him on YT. However, the difference between him and I is that he must make it at least mostly successful... I can afford to fail, and hardly sell anything. In fact, I am considering donating machines to people interested in developing for them. Though, I would not exclude the possibility of monetizing on it.
Perhaps you are correct in saying that I wasn't clear whether I wanted to just emulate vintage systems or develop a completely new system in the "spirit" of the vintage home computers/consoles. It is the latter I want, but I know that capability to emulate other systems would expand its user base. I am not dead set on the components I've chosen, except perhaps for the RISC-V MCU. If there are better off the shelves chips that are not hard to get, I would gladly consider them for the project. Any suggestions? (Anyone?)
There are so many ideas and thoughts in my mind at the moment about this project that I am still simply unable to share them all without writing a paper on it or starting a YT channel. That may be another reason why I've provided so little info so far. I am open to discussing everything.
Here's a list of some goals / initial specs: (all subject to change)
Hardware:
1 x RISC-V MPU @ 144 MHz (or more?)
1 x Video, i.e. VGA / HDMI out
1 x RAM / Flash
1 x Stereo Audio (DAC and synth would be great)
Connectivity:
1 x 15-pin VGA Output / RGB via SCART at 15 kHz
4 x USB Ports (Keyboard, Mouse, Storage, Controllers, additional USB hub ICs might be needed)
1 x Stereo sound output using 3,5 mm jack.
1 x Edge (or other) connector for expansions (Add JAMMA as well?)
1 x Bluetooth
1 x SD-Card Reader/Writer (must be able to boot from SD)
1 x Ethernet
1 x Power connector via USB-C
Dream product:
A collectable new computer in the box with its own custom case, keyboard, peripherals, PSU, and manuals. Available as 1) DIY kit 2) bare PCB, or 3) fully boxed and collectable.
