Author Topic: I would like to make my own AMD Phenom Two X6. Is liquid cooling practical?  (Read 3983 times)
Offline LawsenTopic starter
If I am working more, then I would like to build an AMD Phenom Two X6.  I would like this super desk bottom tower.  Is liquid cooling practical?  Are there motherboards with two AMD Phenom Two X6 processors?  I think this is excessive, not needed.  I like fast computers.
I have answered my own question by surfing Central Computers store, close to me.  It is 100 miles (161 km).  The AMD Phenom 2 X6 is already 6 cores, more than what I am using currently, core 2 duo at 1.8 GHz by Intel.  The Asus M4A88TD-M motherboard seem is an one AMD Phenom 2 X6, that there are already 6 cores.
I built my own Intel Core 2 Duo awhile ago at 1.8 GHz, because I was not working much and cannot afford a faster computer.  I was forced to upgrade from a Celeron 800 MHz BookPC BK630e that I have used over the years at San Jose State.  It lasted for 6 years and the power supply burned out and none are available to fit inside the small case.
http://www.liberteks.com/power_supply/PS100_bookPC_power_supply.htm
I decided to scrap the small BookPC desktop 630e to electronics waste and kept the disk drives and discard the rest of the computer over a burned out power supply.
I do not need those 6 cores in the AMD Phenom 2 X6.  I would like to use it for Auto CAD to design telescopes and recumbent bicycle concepts.  I do not have geology modeling, rheology.  Rheology is study of fluid matter, which the earth's mantle is a fluid matter and semi sold clay soils and saturated sands and soils are a fluid matter, viscous and oozing flow, "quick sand," and tars and goop low grade crude oil, and yuk.  You could not suctioned into quick sand, that is just saturated sand.  It is easier to float on quick sand than water, because quick sand is more denser, just carefully swim in it, messy, yuk.  The movies exaggerated about quick sand, a semi fluid, saturated sand.
http://en.wikipedia.org/wiki/Rheology
Lawsen
« Last Edit: April 19, 2011, 06:03:27 pm by Lawsen »
Offline gundog48
Well, this is my specialist subject :)
Can you clarify what you mean by 'making your own Phenom II x6' please? Do you mean building a computer based around a Phenom II x6? Or do you mean using 2 of them in one system?
This probably isn't the best forum for these question, I would recommend somewhere like Overclockers UK. Although I will be able to help you with this with no worries :)
Just let me know what you mean and I'll help you out.
Offline Polossatik
mineral oil cooling can do wonders...
but really.... a 12 core system? to do what? I assume you will be earning really really $$$ :)
« Last Edit: April 18, 2011, 10:12:35 pm by Polossatik »
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
Offline Ed.Kloonk
  • Cat video aficionado
Bitcoin?  ;D
iratus parum formica
Offline gundog48
You cannot get a duel socket AM3 motherboard, you will need to go Intel if you want that. I would wait for the new AMD Bulldozer CPUs to become available as they use a brand new architecture that should see better real world speeds. Plus some of these CPUs will be 8-core which should be plenty for encoding. If you want a fast computer for gaming and general use, do not look for cores, get a 4 or even 2 core CPU with a high clock speed. And it pains me to say it as a Phenom II x6 owner, Intel will be a lot better for gaming and general use.
Also, if you are looking for general responsiveness get yourself a nice SSD. Maybe even look at the OCZ Revodrive x2 which is amazingly fast but super-expensive.
Offline GeoffS
I have a AMD Phenom II X6 1090T on a Gigabyte board and I can't imagine I'd ever need a second CPU. It's very quick indeed.
All it really needs is some more  memory (currently 4GB but upgrading to 16GB)
What do you want to do that requires so much CPU power?
Offline gobblegobble
You better also have more than plenty of free cash and/or time at your disposal. ;D
If you want your computer properly watercooled, to my knowledge it's more or less a DIY project: you can get the parts relatively easily but the assembly needs to be done. That being said, why do you want it watercooled? It's not as maintenance free as aircooled option and there is little benefit when comparing to properly built air-cooling unless you do overclocking or similar stuff.
As for the multiprocessor platforms, you need to step up from desktop processors and motherboards to workstation processors and motherboards: the AMD processors lineup for that are called 'Opteron' (apart from the name, they're still same stuff but the new brand name justifies higher price tag) while the Intel equivalent runs under the name 'Xeon'. Prices starting at "if you have to ask, you probably can't afford it". Apart from the hefty price tag there isn't much difference to desktop equivalents so the question stands whether you want to spend enormously cash for building such a rig?
