Author Topic: Removing tarnish from high voltage high vacuum feedthrough  (Read 542 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: March 03, 2021, 08:30:06 pm »
Hi!
I've just received this really nice NOS MDC vacuum feedthrough. It's a hollow 1/4" copper tube insulated through the vacuum flange by about 18mm of ceramic insulator.
I guess its hollow for high powered applications where the electrodes themselves has cooling water running in them. I'm unsure. I'm gonna seal it with a blob of Sn/Ag solder.
Either way, how would one go about removing the copper tarnish? Abrasives are bad, as fine particles are difficult to get rid of.
Maybe dilute hydrochloric acid or 30% acetic acid?
I'm worried about galvanic corrosion, and deterioration of the metal/ceramic seal...
Also, could anyone venture a guess on the max operating voltage?
Thanks in advance!
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline Tomorokoshi
Re: Removing tarnish from high voltage high vacuum feedthrough
« Reply #1 on: March 03, 2021, 09:05:53 pm »
That's tricky because of the special conditions. Perhaps one of the Deoxit series:
https://caig.com/
    • My channel:
« Reply #2 on: March 03, 2021, 09:28:16 pm »
That could be, I will look for an equivalent brand in the EU. Thanks!
Either way I will try not to expose the ceramic. The inside of the tube could be cleaned by just pushing liquid through a hose attached on each end, and the outside ends with a rag.
Offline vindoline
« Reply #3 on: March 04, 2021, 12:11:09 am »
Chris, it's not clear to me why you want to clean the copper. However, since you're a chemist, you can brush on a solution of sodium chloride and citric acid. That will strip the oxide off the copper.   I don’t imagine it will effect the copper/ceramic junction.
