Author Topic: Modular Interlocking Enclosure  (Read 2653 times)
Offline garbouiTopic starter
« on: August 24, 2016, 12:25:33 pm »
Having worked in industrial automation for some time in the past, having modular enclosures for PLC's was almost standard. What I am talking about are systems like the Beckhoff PLC's where there is a main controller then peripheral cards just snap in along side one another. No backplane is needed because there are communication bus contacts on the sides of the cards.
Has anyone ever come across similar enclosures that were COTS items? I would like to try and find a COTS solution first instead of going to a full blown custom injection molded solution. The enclosures can be plastic or aluminum extrusions. Post machining to be able to integrate a contact system is also acceptable.
Offline ajb
Re: Modular Interlocking Enclosure
« Reply #1 on: August 24, 2016, 03:11:04 pm »
Are you specifically looking for DIN rail enclosures?  I know Weidmuller have some neat ones, not sure if they have ones that integrate side-to-side connectors.  Given a suitable base housing that you're willing to machine, though, I would think that it's just a matter of a suitable connector mounted at the right height (maybe need a mezzanine board or extra-long pin headers) in the enclosure, isn't it?
Offline nanofrog
« Reply #2 on: August 24, 2016, 03:24:19 pm »
You might want to take a look at the VMS modular series from GE.
Offline CM800
« Reply #3 on: August 24, 2016, 04:12:15 pm »
I've been looking out for something like this myself.
the closest I have come is finding some nice little surface mount connectors and designing them in. (pin header and socket)
Online nctnico
« Reply #4 on: August 24, 2016, 04:22:25 pm »
TE has hermaphrodituc connectors like these:
http://www.te.com/catalog/common/images/PartImages/pr1954289.jpg
You can have these on a small (passive) backplane which sits in the DIN rail.
« Reply #5 on: August 24, 2016, 09:46:01 pm »
DIN is not a requirement. Connectors at the right height solve one problem (the blade style connectors typically used for laptop batteries work well in this situation) but even finding an enclosure that has the dovetailing to allow easy connection is difficult. Extra hardware to join segments is not preferable.
Looks interesting, I will have to take a closer look at these tomorrow.
Having a backplaned arrangement will be a non starter for this project.
EDIT: does anyone have a picture of the inside of one of those beckhoff modules (or similar)? Im interested in seeing how they do the spring loaded wire terminals (sometimes 16 positions) in such a small space.
« Last Edit: August 24, 2016, 09:47:44 pm by garboui »
Online nctnico
« Reply #6 on: August 24, 2016, 09:59:30 pm »
As a sidenote: I'd go for a backplane. Having many modules connected through a string of connectors increases the risk of a bad connector causing problems in all the downstream modules. If you insist on using connectors on the side of a module you could look for spring loaded battery terminals like these:
and use a gold plated PCB as the other end.
You can buy readily made DIN rail housings and have them CNC machined cheaply to fit the connector.
Offline qwaarjet
  • Use your imagination and pretend its linear.
« Reply #7 on: August 25, 2016, 02:55:46 am »
phoenix contact have variety of housings like what you are describing
can do a a whole diy PLC system if you like and look fairly similar the the Beckhoff units I have used.
https://www.phoenixcontact.com/online/portal/us?1dmy&urile=wcm%3apath%3a/usen/web/main/products/subcategory_pages/Electronics_housings_P-01/bf184df7-b458-487a-81f6-a86ac6c22e9d
« Last Edit: August 25, 2016, 02:59:32 am by qwaarjet »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #8 on: August 25, 2016, 09:20:07 am »
Yes. Phoenix HBUS, ME-TBUS or UT-BUS, or BOPLA Combinorm.
Or you ask any manufacturer to mill out a part of some other random enclosure. They'll do this for quantities.
« Last Edit: August 25, 2016, 09:22:48 am by Jeroen3 »
Offline dekra54
« Reply #9 on: August 25, 2016, 07:41:09 pm »
Italtronic also might have something that fit your needs.
Gesendet von meinem SM-G900F mit Tapatalk
