Author Topic: JST Series Type  (Read 1385 times)
Offline bostonmanTopic starter
JST Series Type
« on: July 07, 2021, 02:24:40 pm »
Does anyone know what series JST connector this is?
I'm measuring 8.2mm wide and 4mm height (not including the two plastic guides that protrude out). From looking at different series, I can't find any that are 8.2mm wide. The closest I've come are 7.9mm.
Offline Monkeh
Re: JST Series Type
« Reply #1 on: July 07, 2021, 02:37:49 pm »
Just your every day XH.
Offline ajb
Re: JST Series Type
« Reply #2 on: July 07, 2021, 07:41:10 pm »
Yeah, looks like an XH.  It's a lot easier to go by the connector pitch, since that's a spec that's more commonly used and can usually be filtered on at distributors.
Re: JST Series Type
« Reply #3 on: July 08, 2021, 12:56:31 am »
It looks like a pitch of 3.30mm.
I had looked on Wikipedia prior to my post, and didn't see what fit mine.
Offline sleemanj
  • Professional tightwad.
Re: JST Series Type
« Reply #4 on: July 08, 2021, 01:27:55 am »
Quote from: bostonman
Pitch is between the centers of two adjacent pins (or in your case, the center of  one end pin and the center of the middle space where a pin would be).
Since you measured the 3 pin plug to be 8.2mm wide, then a pitch of 3.3mm is impossible :-)
XH is 2.5mm pitch, and your plug looks like XH to me
Re: JST Series Type
« Reply #5 on: July 08, 2021, 01:52:39 am »
It wouldn't be impossible, it would just leave very little between the edges and side pins - but you're correct, it's an impossible design to have.
This is hard to measure. Placing the calipers in the holes, and I get over 3mm, holding it aside of the holes and manually centering it does place me in the 2.5mm range. I can't fit the calipers in the female end.
I'll go with the majority input of 2.5mm.
Offline sleemanj
Re: JST Series Type
« Reply #6 on: July 08, 2021, 02:21:42 am »
If using a digital caliper, an easier way to measure pitch than eyeballing centers is usually to set your caliper to the width of 1 pin and then zero it, then measure the outside distance from one pin to the next, this will get you the pitch between two consecutive pins (outer distance minus 1 pin width).
Offline Siwastaja
Re: JST Series Type
« Reply #7 on: July 08, 2021, 01:56:30 pm »
Obviously, to obtain the pitch of an n-pin connector, measure between the far end pins and divide by (n-1), this reduces any measuring error by factor (n-1).
2.5mm is easy to verify, with just 3 pins it should align pretty well on a standard 2.54mm pin header.
Offline ajb
Re: JST Series Type
« Reply #8 on: July 08, 2021, 03:11:52 pm »
Another way to get a more accurate pitch measurement is to measure from one edge of the pin/hole to the same edge of the next pin/hole.  Lining up to edges is easier than trying to eyeball a center position.  A lot of connector pitches are going to be either a nice round metric measurement (0.5, 0.7, 1, 1.5, 2, 2.5, etc) or a multiple or half-multiple of 100mil/2.54mm, although there are some popular oddball sizes like 3.96mm.
Offline xavier60
Re: JST Series Type
« Reply #9 on: July 08, 2021, 11:28:49 pm »
That's how I do it also. It works well in other situations like measuring the pitch of screw holes or studs. Taking the measurement over a larger number of pins then dividing, would reduce the error.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline viperidae
Re: JST Series Type
« Reply #10 on: July 09, 2021, 10:37:15 am »
Isn't 3.96mm 5/32 of an inch? I'm a native metric speaker, but I always assume things that don't make nice round numbers in metric are based on imperial.
Offline phil from seattle
Re: JST Series Type
« Reply #11 on: July 10, 2021, 04:42:33 pm »
Yes but there aren't a lot of possibilities. 3.81mm springs to mind - 150 mils/.15".  And let us not forget the most common pitch out there 2.54mm (0.1").  I think it more likely to be measurement error that gets an odd pitch value. Realistically, there are only a few likely pitch values.
