Author Topic: IC advice to create a regolable oscillator from 0 to 500kHz  (Read 7412 times)
Offline YarooooTopic starter
« on: March 29, 2019, 11:17:42 am »
Hello,
I'm looking to create a circuit that allow me a square clock generator that is regolable. I've found 555, but max. clock is 100kHz, AD654 but seems not suitable.
What I'm looking for is 2 selectable Potenziometers that allow 1 clock output regulation. First, if selected, an output from 0-100Hz and another that goes from 10kHz to 500kHz.
Best regards!
Offline Zero999
  • 0999
Re: IC advice to create a regolable oscillator from 0 to 500kHz
« Reply #1 on: March 29, 2019, 12:17:24 pm »
The ordinary 555 can go up to 500kHz, the ICM7555 1MHz and the TLC555 2MHz.
https://www.st.com/resource/en/datasheet/cd00000479.pdf
https://www.renesas.com/eu/en/www/doc/datasheet/icm7555-56.pdf
http://www.ti.com/lit/ds/symlink/tlc555.pdf
Logic gates such as the 74HC14 can work at even higher frequencies, but are less accurate.
What are your tolerance/accuracy requirements?
« Reply #2 on: March 29, 2019, 02:06:05 pm »
I'd like to generate a 50% duty cycle, any particular tolerance or accuracy. It's just for debug propuses so, if it's not a perfect 50% duty or frequency is not stable, it's not a problem.
That's why I'm looking for a simple solution. I've seen NE555 from ST have a good documentation.
To be able to generate a 500kHz as example, I should look at 4.5 50% duty cycle oscillator, where is written:
t1 = 0.693*RA*C
f=1/(t1*2)
I calculate t1 = 0.693*180ohm*0.01uF = 1.25uS than a freq. of 400kHz?
Seems strange to me since small resistors. Can you kindly check if my logic is correct?
Offline SiliconWizard
« Reply #3 on: March 29, 2019, 03:38:32 pm »
One simple option to get an accurate 50% duty cycle is to put a D-type flip flop (such as the 74HC74) after the oscillator to divide the output frequency by 2, which would give you a 50% duty cycle with no effort. As said above, you can find 555's that can work up to 2MHz, so getting 500kHz would be no problem, or build an oscillator around a Schmitt trigger inverter.
The tricky part will be the wide frequency range you're targetting. Doing that with just one simple RC oscillator will be challenging. If you want your oscillator to be able to switch seemlessly between the two ranges it may not be that simple. Now if you can accept glitches during the switching, that's just a matter of using a switch and switching between two capacitors for instance.
Offline Zero999
  • 0999
« Reply #4 on: March 29, 2019, 04:43:49 pm »
t1 = 0.693*RA*C
f=1/(t1*2)
Try reducing C by a factor of 10.
That circuit will not give a stable duty cycle, if a variable resistor is used, because the duty cycle is dependant on the ratio of two resistors.
If you're going to do that, you might as well use one half of the 74HC74 as an astable. Here's a circuit I whipped up in another thread. Change the resistor and capacitor values to alter the frequency.
https://www.eevblog.com/forum/beginners/portable-low-frequency-square-wave-generator-circuit/msg2155480/#msg2155480
The following users thanked this post: schmitt trigger
Offline coppercone2
« Reply #5 on: March 29, 2019, 05:00:57 pm »
what is regolable? i never heard that term
Online Marco
« Reply #6 on: March 29, 2019, 05:44:11 pm »
A synonym for adjustated.
Offline soldar
« Reply #7 on: March 29, 2019, 07:52:45 pm »
I knew a guy who adjustated synonyms for a living.
Offline Zero999
  • 0999
« Reply #8 on: March 29, 2019, 08:15:53 pm »
There's no such word in English. I did try Googling it, but guessed the OP meant adjustable by their context.
Offline ogden
  • Country: lv
« Reply #9 on: March 29, 2019, 08:37:55 pm »
Seriously? Only two guys who did not get English typos are from US and UK  :-DD  [kidding]
Back to the subject.. There are many programmable clock IC's around, such as CDCE913, Si5351 and more. [edit] Not to mention nearly every microcontroller with and without timer.
https://www.adafruit.com/product/2045
« Last Edit: March 29, 2019, 08:40:50 pm by ogden »
Offline coromonadalix
Offline David Hess
  • DavidH
« Reply #11 on: March 29, 2019, 11:10:37 pm »
Voltage-to-frequency converters commonly cover that range easily and with the addition of an output flip-flop, will produce a square wave.
« Reply #12 on: April 01, 2019, 07:55:49 am »
t1 = 0.693*RA*C
f=1/(t1*2)
I don't really need a 50% duty cycle, as I said it's just for test purposes, so will never feed something that require particular clock parameters.
About 555, so, if I place small Res like 150 and 1.5k, with a 0.001uF , this will be a good choice of resistors and capacitor for this IC? I'll able to generate about 400kHz.
Than I'll regulate my frequency with a POT in series to 1.5k. Theoretically, since R1 is very small (150 R), I'll able to get between 50.5% and 53% duty cycle.
I'm right with this assumptions?
I'd liked your version with D-FF, I've tried to simulate it but I've got some problems.
https://www.falstad.com/circuit/circuitjs.html?cct=$+1+0.000005+14.235633750745258+74+5+43%0Ac+80+112+128+112+0+3.3000000000000004e-8+-2.508638357675748%0Ac+80+176+128+176+0+0.000001+-2.5001005324319188%0Ac+80+368+128+368+0+0.0000010000000000000002+-2.4956407383303683%0A155+240+208+304+208+6+5%0A155+400+176+464+176+6+5%0Aw+496+240+512+240+0%0Aw+512+240+512+256+0%0Aw+400+240+384+240+0%0Aw+384+240+384+256+0%0Ag+512+256+512+272+0%0Ag+384+256+384+272+0%0Aw+400+176+384+176+0%0Aw+496+208+512+208+0%0Aw+512+208+512+144+0%0Aw+512+144+384+144+0%0Aw+384+144+384+176+0%0Aw+496+176+528+176+0%0AO+528+176+544+176+0%0Aw+400+208+336+208+0%0Aw+240+240+208+240+0%0Aw+240+208+208+208+0%0Aw+208+208+208+240+0%0Aw+208+240+208+256+0%0Ag+208+256+208+272+0%0Ar+176+112+256+112+0+22000%0Ar+352+368+416+368+0+470%0As+128+336+128+272+0+0+false%0A174+272+368+320+368+0+1000+0.1733+Resistance%0Ag+64+400+64+416+0%0Aw+80+112+80+176+0%0Aw+80+176+80+368+0%0Aw+80+368+64+368+0%0Aw+64+368+64+384+0%0Aw+64+384+64+400+0%0Aw+128+368+128+336+0%0Aw+128+208+128+176+0%0Aw+128+112+160+112+0%0Aw+160+112+160+320+0%0Aw+160+320+336+320+0%0Aw+336+272+336+320+0%0Aw+160+112+176+112+0%0Aw+256+112+336+112+0%0Aw+336+112+336+208+0%0Aw+224+368+192+368+0%0Aw+240+272+240+304+0%0Aw+240+304+240+368+0%0Aw+272+368+240+368+0%0Aw+240+368+224+368+0%0Aw+192+368+128+368+0%0Aw+352+368+336+368+0%0Aw+336+240+352+240+0%0Aw+352+240+352+320+0%0Aw+352+320+432+320+0%0Aw+432+320+432+368+0%0Aw+416+368+432+368+0%0Ar+128+208+128+272+0+100%0Ao+17+1+0+4106+5+0.1+0+1%0A
Seems not able to regolate it with POT, also sometimes it freeze. Something wrong?
Adj. is the correct word. Sometimes due my language some words seems also correct in english.
I'd like to use something simple and cheap. I know there's micro and advanced regulators but it's something I don't want to use.
Offline Zero999
  • 0999
« Reply #14 on: April 01, 2019, 08:10:08 am »
Yes, but 150R is a little on the low side. I'd probably go for C = 330pF, R1 = 390R and a 4k7 potentiometer.
That means nothing. Simulators are notoriously bad at modelling digital logic chips. I've built it before and it worked perfectly, although I admit I used the CD4013, not 74HC74, but it should work with that too.
« Reply #15 on: April 01, 2019, 08:21:58 am »
Thanks for your advise.
Anyway, about D-FF circuit, how can I simulate it using a valid simulator? I admit Falstad seems an entry level simulator and may fail.
Offline Zero999
  • 0999
« Reply #16 on: April 01, 2019, 11:37:13 am »
Why do you want to simulate it? There's little point in doing so. It won't actually prove whether it works or not. The simulator will only be as good or bad as the component models.
You could try LTSpice, but it's a lot of effort, because it doesn't come with the CD4013/74HC74 in the default model library.
Try building it on a piece of breadboard. Start with larger capacitors to give a lower frequency, which will be easier to work with on a breadboard, which is not ideal for high frequencies.
Offline iMo
  • Country: va
« Reply #17 on: April 01, 2019, 12:00:59 pm »
You cannot get 50% duty off a 555. The math does not allow it.
You may use the wiring with two diodes in the lower resistor, that works well (tested in hw).
See below the 555 with regolable duty and frequency/
« Last Edit: April 01, 2019, 12:18:23 pm by imo »
Offline Zero999
  • 0999
« Reply #18 on: April 01, 2019, 12:35:08 pm »
The 7555 will theoretically give 50% duty cycle, with the timing resistor connected to the output.
However in practise, it won't give exactly 50% duty cycle. I've built it before and it's slightly off, depending on the value of R and the power supply voltage. Generally, it gives better results with as higher power supply voltage and value of R, as possible, but it's dependant on the device, which is pot luck. See the thread linked below.
https://www.eevblog.com/forum/beginners/portable-low-frequency-square-wave-generator-circuit/msg2167870/#msg2167870
This is why simulation is not the answer. If you tried simulating the above circuit, it will no doubt give exactly 50% duty cycle, but it doesn't in reality. Indeed the default LTSpice model for the NE555 gives 50% duty, with this circuit, but a real 555 timer won't. The simulator is wrong, because it doesn't model the 555's output stage properly.
Offline ogden
  • Country: lv
« Reply #19 on: April 01, 2019, 01:10:28 pm »
To get 50% duty cycle, build 0..1MHz clock and divide it by two:
https://www.electronics-tutorials.ws/counter/count_1.html
Offline Zero999
  • 0999
« Reply #20 on: April 01, 2019, 04:21:03 pm »
That's what the circuit I posted above does, but the original poster appears to lack confidence in it, because it doesn't work with a simulation program.
There are lots of circuits like that which won't work in simulation very well. What's worse is there are circuits which will work in a simulator, but not in real life. Here's an example of a circuit which is supposed to both generate an inverting and non-inverting output, with a gain of 10. A simulator will show it works, but it doesn't in real life,
The following users thanked this post: ogden
Offline Kleinstein
« Reply #21 on: April 01, 2019, 07:58:09 pm »
The 74HC4060 could be suitable. A simple RC oscillator that could be adjusted with a pot, and quite a few divider stages to select for the lower frequency. because it's a ripple counter the outputs are near perfect 50% PWM.
The stability is not great, but could be a little better than HC14 type.  As the analog range would be only about 1:4 the adjustment could be relatively fine. Overall range could be something like 1 MHz .... 1 Hz or a little larger.
« Reply #22 on: April 02, 2019, 07:29:43 am »
No wait. I've just asked to learning purposes. What I've asked is why is not working and I can't simulate it, to understand what's happening. But I had interesting answers to make me understand better.
Offline iMo
  • Country: va
« Reply #23 on: April 02, 2019, 07:50:41 am »
If you want to learn something useful, download the LTspice and you will get a tool which works..
« Last Edit: April 02, 2019, 07:58:30 am by imo »
Offline Zero999
  • 0999
« Reply #24 on: April 02, 2019, 09:05:17 am »
Does the astable with the 74HC74 work though?
Oh did you try building it and it didn't work? If the 74HC74 didn't work, try the CD4013, I've build it with that IC and it worked perfectly. I didn't try the 74HC74, although it should work with that too.
The link you posted to the simulation doesn't work. Try [url]link[/url]
« Last Edit: April 02, 2019, 09:07:29 am by Zero999 »
