Even the expensive multimeters seem to lack features that are easily feasible today. Even stuff as basic as graphic LCDs and display of multiple values at once. So how about design an open source multimeter?
A preliminary list of features:
*DC-20kHz bandwidth (That means a sampling rate of about 200kHz, very easily attainable.)
*+-32768 counts (16 bit) or greater at DC
*LCR measurement
*1kV CAT III rating
*separate voltage, current, and impedance connectors, with connector checking
*"soft" pushbutton controls (That is done to allow remote operation if equipped.)
*Transflective color LCD with LED backlight (backlight off by default, maybe with ambient light sensor to automatically set backlight)
*Bluetooth or optoisolated USB (optional)
*Lithium ion or NiMH battery with integrated charging (NiMH is more common in stores, but Lithium ion offers superior energy density)
*target price $50-$150 (parts only) depending on features
And here's a list of how some things could be implemented:
*ARM CPU, perhaps a Cortex M3. Firmware and user data is stored on a SD card in the battery compartment, allowing the user to easily swap it.
*The input voltage divider could consist of a precision high voltage resistor from the input terminal to the buffer, with precision resistors to ground switched in and out by electronic switches and a pair of large zener diodes for transient protection.
*Hall effect current sensing for extremely low insertion resistance on high mA and A ranges, active I-V converter for uA and low mA. A relay switches between the two, with a pair of shunt diodes to ground and a HRC fuse for protection.
*24 bit ADC, so calibration can be handled digitally (Dual channel 24 bit, 192kHz ADCs are common for audio. One channel could be connected to the voltage divider circuit and the other to the current sense circuit, allowing for simultaneous voltage and current measurement.)
*The impedance input protection could consist of a HRC fuse, a pair of doubled shunt diodes (or other overvoltage protector) to ground, and fusible resistors to the current source and voltage sense. The doubled (or tripled, etc.) shunt diodes allow for enough output voltage for semiconductor testing.
*The power supply could be integrated, accepting 100-240v AC or 140-340v DC. Alternatively, an isolated DC/DC converter could be integrated, accepting 12v from an external power supply.
*The software, of course, would be open source so any feature possible with the hardware could be implemented.
