Author Topic: RC car Motor help  (Read 777 times)
Offline ironasonaTopic starter
RC car Motor help
« on: March 04, 2021, 10:09:12 pm »
I was told to make a RC car that can go vertically up a 180 degree angle tube , 2m , and i wanted to ask what type of motor would i need to be able to do that ,car weight is 600grams. or is there a calculation for that .ty )
« Last Edit: March 04, 2021, 10:11:51 pm by ironasona »
Offline fordem
  • Country: gy
Re: RC car Motor help
« Reply #1 on: March 04, 2021, 11:01:59 pm »
What's a 180 degree angle tube?  My grandson has a couple of toy cars, they are remote controlled cheapies, they'll drive up a flat vertical surface (which is what 180 degree angle means to me) , they'll even drive across a flat ceiling.
« Reply #2 on: March 04, 2021, 11:07:34 pm »
sorry i meant to say a RC car that can climb a vertical tube in a 0.145m diameter tube
Offline Zero999
  • 0999
« Reply #3 on: March 05, 2021, 01:24:16 pm »
How fast?
The motor and gearbox, just needs to provide a force of f = mg, on the outside of the tyres, where m is the mass in kg, 0.6kg in this case, and g is the gravitaional acceleration of the earth: typically 9.8N, giving 0.6*9.8 = 5.88N.
Suppose the car needs to travel at 2m/s. P = f*s = 5.88*2 = 11.76W.
In reality there will be losses, so the motor and any electronics driving it, will need to be rated to much more power.
Offline fordem
  • Country: gy
« Reply #4 on: March 06, 2021, 11:29:18 am »
As I mentioned, my grandson has a couple of toy cars, that are capable of driving up a flat vertical surface, or even across the ceiling - they're powered by two AA cells, I don't see AA cells lasting very long powering an 11.76W load.
The challenge as I see it, is maintaining sufficient traction - the car can't climb the wall unless it has sufficient traction - my grandson's toy does it through what can be considered a "reverse hovercraft" principle - a thin flexible rubber skirt just long enough to bridge the gap between the chassis of the car and whatever flat surface it's on, and a fan to create a vacuum to pull the car against the surface.
The weight of the vehicle is obviously going to be a critical factor.
Is RC Remote Controlled or Radio Controlled?  My grandson's toys are radio controlled, so self contained, but you can do remote controlled using a wired controller which would enable you to put the power source in the controller, thus reducing the weight.
