Electronics => Projects, Designs, and Technical Stuff => Topic started by: FenderBender on February 29, 2012, 09:55:06 pm
I made a thread before regarding battery chargers except with Li-ion that time. I've decided that I would like to use NiMh in my project, specifically a 9.6V (8-cell) "9V" battery.
Problem is: There seems to be a lot of ways to charge these things and I'm not sure what's good or not. I was thinking of having a simple constant current charger. Perhaps a ~12V input into an LM317 constant current. C/10 charging I would guess.
Any other interesting ideas?
Thanks.
With a series string or pack of NiMH the important thing is to keep all the cells balanced.
The easiest way to accomplish a balanced charge is to use C/10 for about 12-14 hours as the charging method.
When a pack is known to be in good balance you can get away with a C/2 charge with minus delta-V termination, but even when doing this you should periodically re-balance the pack with a timed C/10 charge.
When discharging, try to put the low battery cut-off at 1.0 V per cell or higher, maybe even 1.05 V per cell. This is to avoid damaging any weaker or unbalanced cells in the pack by reversing their polarity.
Interesting. Thank you.
I'm not so sure about the low voltage cuttoff. I think that might be harder than it seems, since I don't plan on using any micros and I'm trying to keep it as small as possible.
Is there a crude way to do that?
I'm not at all an expert in low battery management circuits or solutions, but I think simple cheap solutions might be tricky unless you can find a dedicated chip for the job.
Possibly the simplest solution of all is to arrange that the circuit being powered stops working when the supply voltage gets below 8 V or so, so that users are encouraged to stop and replace/recharge the battery.
If the device power consumption is low the risk of damage to the battery is lower, but 9.6 V NiMH batteries are notorious for short life and early failure due to excessive discharge during use. It's a risk you take with multi-cell NiMH solutions.
Try search for MAX713 IC from Maxim. It's a dedicated charger IC specific for NiMH battery. Free samples are available thou. ;D
Max713 has been out of production for a while. Not saying that it's bad.
And Ian thanks. I might try looking at something like a shunt regulator to get a cutoff for the battery.
The DS2715 is similar and active.
Apart from NiMH and 9.6v you have given zero information about your requirement so it is hard to offer any useful advice.
