Hi guys,
Got a quick question regarding IC selection. I am trying to add analogue video input to a raspberry pi like device for a project I am working on.
This device has a standard pi header, as well as the CSI input.
My analog video can be either NTSC or PAL.
My intent originally was to get a one chip solution to convert from PAL/NTSC to MIPI CSI. I found the ADV7280-M. This chip is perfect in all aspects bar one.... It costs AUD$14.66 in single quantity.....
The other thing with this chip is that it offers 8 analog inputs to switch between.... This is something I dont really need.....
I had considered using something like a TVP5150AM1 then a FPGA to translate the parallel 8-bit ITU-R BT.656 format into CSI. but am still new to this field and would have to spend a very long time working this out....
So my question is, has someone done something like this before and/or can recommend a cheaper option? I am open to using either CSI or another input method. I am also not objecting to using intermediary formats and multiple ICs.
Thanks, and I welcome your guys thoughts.
