Author Topic: High impedance voltage measuring?  (Read 1901 times)
Offline ArtlavTopic starter
  • Country: mon
    • Orbital Designs
« on: November 05, 2014, 01:22:05 pm »
Let's say you want to measure voltage on an 0.1u capacitor, without affecting it (much).
You touch multimeter probes to it, the display flickers for a moment and reads 0V.
Oops, it's discharged now.
So, how can you do it?
I think something like a buffer on an ultra-low input leakage op-amp might work, but maybe there is a simple trick or tool for this?
Offline robrenz
  • Real Machinist, Wannabe EE
Re: High impedance voltage measuring?
« Reply #1 on: November 05, 2014, 01:41:15 pm »
An Electrometer will typically have greater than 100 TOhm input impedance and can easily do this.
Offline HKJ
    • Tests
« Reply #2 on: November 05, 2014, 01:52:26 pm »
At low voltages some meters can be switched to a high impedance input.
Offline dannyf
« Reply #3 on: November 05, 2014, 07:16:22 pm »
A 0.1uf capacitor can hold far more charges than what's needed to perform an adc, especially one with high impedance input (like a digital multi-meter).
If the capacitor is of very low value, like in the pf territory, you can either use a low-leakage high impedance converter to buffer it; or rely on charge transfer - only if the meter's own capacitance is known.
