Hi guys!
I am doing my bachelors project. And I am building a current measurement device where you have digital feedback from embedded systems. Hard to explain in short, but if and when I finish I will share details. It is simular to Dave's uCurrent, but with additional information when you are optimizing your firmware.
I am measuring current using multiple shunt resistors, which are multiplexed with ADG1604(analog mux), to achieve low burden voltage. Then the voltage drop on shunt resistors is amplified using an instrumental amp INA110(very good in many parameters). The device is like a test instrument, where it is automatically controled with MCU.
The current range is from few nA(5-10nA) up to an Amp. I know for high current region, I need additional switching shunt, cause the drop is high on analog MUX's. The maximum voltage for the device which is measured is 12V.
Do you guy have any thoughts is there a better way to amplify or measure the current? Your feedback will help for my theory part and over all device performance.
I have heard about transimpedence amp's, but I am not sure they would work on this large amp range.
