Author Topic: DC-DC converter connection question  (Read 1987 times)
Offline xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: August 10, 2016, 03:39:03 pm »
Maybe this is a dumb question but ...
I want to power a DC-DC converter from a +13.8V supply. The output of it will be adjusted to about 7V to 8V, but - the output will be used as a negative voltage to bias a circuit in a radio, the radio being powered from the same +13.8V supply. So, to have a negative V to the bias circuit, I'll have to ground the positive output of the DC-DC converter, which will obviously then be connected to the input negative supply to the converter, again the same supply the radio is using. I am assuming that won't damage the converter - am I correct?
Offline jeroen79
Re: DC-DC converter connection question
« Reply #1 on: August 10, 2016, 05:38:48 pm »
It depends. Will you be buying or DIYing?
If you are buying an existing design you have to check how it is designed.
Some will have a floating output, others will have one of the inputs tied to one of the outputs. (often a common negative)
If you are building something yourself then you make the outputs floating or tie positive out to negative in.
Offline ovnr
  • Country: no
  • Lurker
« Reply #2 on: August 10, 2016, 05:56:25 pm »
A simple buck converter will die. You need an inverting converter which already gives a negative output voltage by default, or an isolated DC/DC converter.
It sounds like you want a ready-made brick, in which case here are some negative-output converters, and here are some isolated converters where you can safely ground the positive output.
« Reply #3 on: August 10, 2016, 06:12:14 pm »
Good info thanks guys. Exactly what I needed to know.  :-+
Online Someone
    • send complaints here
« Reply #4 on: August 11, 2016, 05:27:54 am »
You can use an inverting or isolated output power supply which will directly create the negative supply, or use a buck regulator with some trickery by connecting its output to the GND as you describe:
http://www.vishay.com/docs/76946/creatingnegativeoutputvoltage.pdf
http://www.ti.com/lit/an/snva022e/snva022e.pdf
