Author Topic: Identify if its a GDT or TVS  (Read 7385 times)
Offline joeqsmithTopic starter
« on: July 10, 2018, 09:48:11 pm »
If you are not aware, we had a tree hit by lightning which damaged a few things.  One casualty was the cable modem.  I took it apart and showed some of the damage.  On the front end there is a device marked as a diode.  At first I thought it may be a TVS but after looking at it with a meter I thought its most likely a GDT.
One viewer stated that the device is a TVS.  I'm going with some sort of gas discharge tube based on my own personal experiences.   I have attached the comments.    What's your guess?  GDT, TVS or some other device?
https://youtu.be/40TaqXOIrHo
Re: Identify if its a GDT or TVS
« Reply #1 on: July 11, 2018, 12:02:31 am »
Picture of the cable modem and the part we are interested in looking at.
« Reply #2 on: July 11, 2018, 12:03:58 am »
Close up views of the unknown device and the damage around the transformer.
« Reply #3 on: July 11, 2018, 12:10:14 am »
« Reply #4 on: July 11, 2018, 12:13:47 am »
Found one.  They don't appear to be as common as the GDT.
https://www.indiamart.com/proddetail/1-5kexxx-tvs-diode-13341138330.html
« Reply #5 on: July 11, 2018, 12:37:50 am »
Under the microscope it looks like a GDT to me.
« Reply #6 on: July 11, 2018, 12:43:13 am »
There appears to be no signs of damage to the part.  The next step is to remove it and mount it onto a test board so we can take a few measurements.
One day I am going to buy a new Pace with some micro tweezers.
« Reply #7 on: July 11, 2018, 12:48:57 am »
My 1970s era VNA is all warmed up and ready.  This is an 8754A that I rebuilt many years ago.  It has the frequency doubler option and the S-parameter test set to go with it.   It would be useless without Labview.
Shown after SOLT and w/ 50ohm standard attached, sweeping to 2.7GHz.
« Reply #8 on: July 11, 2018, 12:51:06 am »
Not sure about consumer market availability, but melf TVS is not rare in defensive/aerospace applications where hermetic seal is a must.
I just Googled "transient TVS glass" and "gas GDT glass".  Then looked at images.  Too lazy to search any other way.    Do you think it's a TVS, GDT or something else?
« Reply #9 on: July 11, 2018, 12:53:10 am »
I suspect if it is a GDT, it will look like a very small capacitor.   Here is a 10pF.
« Reply #10 on: July 11, 2018, 12:55:34 am »
1pF.  VNA is still warming up.
Offline wraper
  • Country: lv
« Reply #11 on: July 11, 2018, 12:56:50 am »
It's certainly not GDT as it has D... designator. Should be bidirectional TVS or zener if it measures open both ways. As it measures open, it should be fine. Very unlikely for TVS to fail open without transient energy which would cause explosion or hole in the package. You could attach it to a laboratory PCU through resistor and check for clamping voltage.
Also it looks just like a diode/zener in melf package.
« Last Edit: July 11, 2018, 01:05:11 am by wraper »
« Reply #12 on: July 11, 2018, 01:04:52 am »
It's certainly not GDT as it has D... designator. Should be bidirectional TVS if it measures open both ways. As it measures open, it should be fine. Very unlikely for TVS to fail open without transient energy which would cause explosion or hole in the package.
I knew someone would not be afraid to voice their opinion.   During the video, I show the meter in conductance both directions.  Let me try it on the electrometer.
« Reply #13 on: July 11, 2018, 01:06:50 am »
I think it could be a GDT, but I just want to say glass TVS does exist.
Well we knew that as I found one.   :-DD   Are you leaning towards a GDT?
Offline wraper
  • Country: lv
« Reply #14 on: July 11, 2018, 01:11:02 am »
Yes. Two smooth parallel plates encapsulated in a hermetically sealed package.
And what is between the plates is exactly like in MELF diode/zener.
« Reply #15 on: July 11, 2018, 01:21:15 am »
Over ranges the electrometer.  Yes, it's connected.  :-DD
Offline wraper
  • Country: lv
« Reply #16 on: July 11, 2018, 01:22:41 am »
I didn't see the silicone or contact.
If you have any and dare to use microscope, you'll usually see round thing (which actually is an optical illusion due to the package) in between of the electrodes. I already posted a pic of a zener which looks very similar. Electrodes of GDT look differently to begin with and there is nothing in between of them.
« Last Edit: July 11, 2018, 01:40:22 am by wraper »
Offline wraper
  • Country: lv
« Reply #17 on: July 11, 2018, 01:31:18 am »
It may look round on the first glance but if you look closer there is a rectangular die.
« Last Edit: July 11, 2018, 01:41:54 am by wraper »
« Reply #18 on: July 11, 2018, 01:58:54 am »
I measured 395pA of leakage at 50 Volts with this setup.   May need to clean things a bit more...
« Reply #19 on: July 11, 2018, 02:02:02 am »
I can imagine they may have an insulator inside to set the gap.  It may all be bonded as one part prior to encapsulation.
« Reply #20 on: July 11, 2018, 02:03:58 am »
Notice on this GDT (yes it's a GDT) how the gap is formed.
« Reply #21 on: July 11, 2018, 02:13:09 am »
Quacks like a duck.   I'm sticking with some sort of GDT.   Next, I need to see where it starts to conduct and how it behaves.
Offline CopperCone
  • *knock knock*
« Reply #22 on: July 11, 2018, 02:18:26 am »
Eh, I don't know if I would bother. You get the best GDT that will fit in the circuit. There is no good reason you can't solder in a better one. Get one with the lowest working voltage you can unless there is some kind of layered protection, which I doubt.
The only GDT parameter would be if it is used in combination with another shunt device with similar voltage, where you would have some kind of impedance (inductor) between the GDT and the other element.
Protection systems = cost. You can always do better.
You could have GDT - > inductive impedance for firing -> Thyristor -> blocking/opening -> fast diodes
If you don't have a thyristor and a TISP or such, you can probably put anything you want there. Clearly the one they put was not up to the job if it exploded. Bourns probably sells faster GDT then what they decided to put in there. You want to minimize the amount of energy going into the semiconductor stuff, thats the only job of the GDT.
« Last Edit: July 11, 2018, 02:21:23 am by CopperCone »
Offline floobydust
« Reply #23 on: July 11, 2018, 03:06:48 am »
I see them as GDT used in car radios. Very hard to find.
Pic is a Ford, also seen in Kia car radios.
Offline wraper
  • Country: lv
« Reply #24 on: July 11, 2018, 08:05:35 am »
GDT with D... designator,  silicon die inside, does not look anything like GDT and has leakage current. Yeah, :palm:. I'd say quacks like a horse.
