Author Topic: Identify PCB?  (Read 903 times)
Offline wd5jfrTopic starter
Identify PCB?
« on: August 22, 2020, 04:07:15 pm »
Found at a hamfest.  Looks like some kind of heavy duty power filter. Any ideas.
Offline wraper
  • Country: lv
Re: Identify PCB?
« Reply #1 on: August 22, 2020, 04:15:57 pm »
3 phase mains filter. Nothing special about it.
Similar to this except it does not have bleeding resistors:
Re: Identify PCB?
« Reply #2 on: August 22, 2020, 04:52:32 pm »
That was quick thanks.
Re: Identify PCB?
« Reply #3 on: August 22, 2020, 06:38:48 pm »
Good inspection but it  has 3 you couldn't see because of the camera angle.The 1.5uf caps are rated at 275Vac.  So it must have been on a 240Vac system.  The toroids are wound with No. 8 wire but the PCB traces would not have anywhere near the current carrying capacity.  The lower resistance of No. 8 wire would result in a higher Q but I wonder if that's important in 60 Hz power filter.  I'm  curious if this was done because they just stocked heavy toroids.
Offline wraper
  • Country: lv
Re: Identify PCB?
« Reply #4 on: August 22, 2020, 07:23:50 pm »
If you look at the schematic I provided, those caps make star connection. So 275V X2 caps work perfectly for 400V 3 phase or anything with lower voltage. And yeah, there are bleeding resistors after all, they were simply hidden on the first photo.
Re: Identify PCB?
« Reply #5 on: August 23, 2020, 12:26:38 am »
Any idea of why they used N0. 8 wire to wind the toroids?
Offline wraper
  • Country: lv
Re: Identify PCB?
« Reply #6 on: August 23, 2020, 07:53:26 am »
It seems that traces to inductors go on both sides of PCB thus have higher current carrying capability that it may seem. Wire thickness does not seem disproportionate to me.
