Author Topic: multipile MC14051B with single dataline  (Read 585 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: August 30, 2019, 02:20:21 pm »
Hi all
I want to use 6 MC14051B with ATMEGA328P for upcoming project. but I am not sure how to connect those to the same data line. in another word, I want all 6 ICs connected to same digital pin (for example PB5).
any guid to do such thing ?
I am learning here btw
regards
Offline Rerouter
Re: multipile MC14051B with single dataline
« Reply #1 on: August 30, 2019, 02:23:52 pm »
Have all the outputs connect to that one data line, have all the A/B/C signals in parallel back to the micro, and then a separate inhibit signal to each chip to select which one you want active.
The following users thanked this post: hussamaldean
  • Country: iq
« Reply #2 on: August 30, 2019, 02:32:02 pm »
so, when inhibit is set to high, it will be HI-Z mode
right?
Offline Rerouter
« Reply #3 on: August 30, 2019, 02:39:29 pm »
Yes, Correct
  • Country: iq
« Reply #4 on: August 30, 2019, 02:40:28 pm »
ok
thank you
