Yes, most of these boards do not connect the backlight PWM pin of the controller IC to the transistor driving the backlight LEDs of the panel, and the PWM pin is rarely made available either, so that's typically not something you can do by simple wiring. I'm afraid you'll have to PWM the BL signal yourself.
