Im looking for a good software package to design PCBs in Linux (or windows if necessary).
I've set out on a project which I probably won't be able to finish on my own, but would like to try to make some of it happen on my own. The first step being drawing the schematic up in some kind of CAD or PCB software which I will attempt to do.
I am planning on trying to build a PAC MAN / Ms. PAC MAN arcade board clone. I will be using a Z80 CPU like the original board. The schematic is available freely online but all of the old 1K ram chips (2114, SL 4239, 93415, 27LS00, MB 81205) are obsolete and quite expensive or unobtainable. This is the part I will definitely need help with.
Maybe its a bit of an ambitious project, but the board isn't insanely complicated so I feel like it should be possible. Although will it be possible without hacking the rom and changing memory addresses due to the use of modern ram?
Anyhow, my first request is advice on a decent software to accomplish this task. I'm running Ubuntu on my computer but have several and can set up a windows pc if required for this. Any suggestions for software
Second is any advice on the RAM for this project? Can the ram chips in this be replaced with something modern?
Thanks in advance!
Schematic available here, it is in "Pac-Man & Ms. Pac-Man Troubleshooting Part II - Midway" manual
https://www.mikesarcade.com/arcade/manuals.htmlAlso attached schematic only below without manual.
