Author Topic: USB power monitor  (Read 3684 times)
Offline PhaedrusTopic starter
USB power monitor
« on: January 22, 2014, 05:21:45 pm »
I'm looking into a simple project to measure voltage and current on USB. Something that would fit between a charger and a tablet, for instance, and report V/A/W to the tablet screen (some software there of course). Just a simple MCU plus a 0.1% shunt resistor and some passives.
What's a good MCU with at least two >8-bit ADCs that would be suitable for this? I've been looking at the TI MSP430, but was wondering if there might be better options.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline kripton2035
Re: USB power monitor
« Reply #1 on: January 22, 2014, 05:31:32 pm »
« Reply #2 on: January 22, 2014, 05:45:55 pm »
Looking for a project, not an off the shelf one. ;)
- Albert Einstein
Offline kripton2035
« Reply #3 on: January 22, 2014, 06:18:19 pm »
usb can pass 2 amps of current, if you want to measure the milliamp, you need a >11 bits for the adc
part from that, any mcu can do the job.
Offline mariush
« Reply #4 on: January 22, 2014, 06:38:29 pm »
Well, go do it then... grab a pic or atmega and a couple of adcs and you can basically do it on a breadboard.
Even 16-18 bit i2c ADCs are a few dollars, and those will give you enough precision to measure up to 2-3 amps with no problems at all.
Offline MLXXXp
« Reply #5 on: January 22, 2014, 07:35:40 pm »
Note that for a mini-USB or micro-USB connection, the extra fifth pin, not present on full size USB, may affect current draw. This pin is sometimes used to indicate that the device is a charger and is able to provide higher current. To do this the pin might be tied to ground, or be on a resistor to +5V or ground, or on a resistor divider between +5V and ground. If you want correct current measurement in this case, you may need to bring this pin through from the charger to the device.
Cables with connections to this pin are very rare. For a mini-USB breakout board that I built, I ended up cutting into and stripping away the plastic of a moulded mini-USB connector, to add an extra wire to the fifth pin. I then sealed the connector back up with wire, solder and heat-shrink tubing.
Attached are some pictures.
« Last Edit: January 22, 2014, 07:38:35 pm by MLXXXp »
« Reply #6 on: January 22, 2014, 07:41:44 pm »
Thanks,
I'd prefer a single chip solution, but I'll throw a cheap 12-bit ADC in there if I need it. For now I'm looking at the ATmega16U4. It does everything I need, except that it requires a <3.6V supply, which isn't ideal for 5V USB. And throwing an inefficient in LDO in there might affect the voltage output of the charger...
- Albert Einstein
Offline notsob
« Reply #7 on: January 22, 2014, 08:48:20 pm »
There's this one that dave showed on a mailbag
http://www.jmedved.com/usbamps/
