What value is Rcs and how much load current is flowing through it? And what voltage drop is it causing across Rcs?
Did you add the extra diode D2 in my last schematic? It will ensure that the LM741 is happy with the input common mode voltage.
Yes, I did in fact use the version with the diode, 10K resistor and 10k pot and I also tested the earlier version of the circuit, although I only included one image in my post.
In any event, I decided to pull everything off of the breadboard and rebuild from scratch and I do think that I made progress, as the circuit behaves differently. The very obvious difference is that I do get a reading in mV across the R9 resistor and when I dial the 10k pot I can make that reading go down to 0V. Also, when I increase the resistance of Rcs that reading increases for a few mV's, just as you said it should.
Since I do not have a 100m Ohm resistor I am using a 110m Ohm value there by connecting two .22 Ohm resistors in parallel. When I said that I increased the value of Rcs I just took one of these resistors out of circuit.
I also made the measurements that you asked for, so here is the data.
The unregulated incoming voltage is +24.3V.
When the power supply pot is at its max the outgoing voltage is now +22.0V
With +22.0V outgoing voltage the readings are as follows:
6.61mA current going through Rcs
0.7mv across .11 Ohm Rcs
1.4mV across .22 Ohm Rcs
With output voltage dialed down to 0V the readings are:
4.73mA current going through Rcs
0.5mv across .11 Ohm Rcs
1.0mV across .22 Ohm Rcs
I hope these readings are as expected and that the circuit behaves properly.
Please let me know what you think.
Thank you very much...
PS - Thank you also for that link.
http://www.ecircuitcenter.com/Circuits_Audio_Amp/Basic_Amplifier/Basic_Audio_Amplifier.htm This is very interesting and educational for me. Although I think there is a typo there. The output buffer stage has Q4 and Q5, but the schematic has them labeled as Q11 and Q12.
