Author Topic: Improving output noise on a DPS3003 power supply module  (Read 815 times)
Offline DG2MMTTopic starter
« on: February 09, 2020, 03:47:20 pm »
Hi everyone,
I had some really nice success improving the output noise of my DPS3003 based power supply and just want to share my findings.
I recently got my first oscilloscope (!) and one of my first measurements was on the output of my power supply. And what I saw was not so good: ringing noise up to 900 mV peak to peak with a 30 Ω load and 12 V output voltage.
After some testing with different parts I got it down to about 90 mV peak to peak, so I would say, this was a full success. ;D
What did I do?
  • Adding a snubber to the switch-node with 2.2 Ω and 620 pF (150 pf || 470 pF)
  • adding a filter to the output with a ferrite ring with 2 windings for + and - and a 100 nF capacitor
And here some pictures:
DS1Z_QuickPrint4.png: Output power supply 1 before modification.
DS1Z_QuickPrint25.png: Output power supply 1 after modification.
DS1Z_QuickPrint26.png: Output power supply 2 before modification.
DS1Z_QuickPrint32.png: Output power supply 2 after modification.
« Last Edit: February 09, 2020, 06:03:28 pm by DG2MMT »
The following users thanked this post: plazma, Kleinstein
Offline Kleinstein
Re: Improving output noise on a DPS3003 power supply module
« Reply #1 on: February 09, 2020, 06:01:48 pm »
Looks impressive for such a small modification.  :-+
The following users thanked this post: DG2MMT
