Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Thermocouple probe temperature range
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Thermocouple probe temperature range (Read 497 times)
dritech
Contributor
Country:
on:
May 05, 2024, 10:37:32 pm »
Hi all,
We are implementing a basic heating block which will reach 350oC.
We intend to use the thermocouple in the link below for monitoring the temperature.
The datasheet states that the temperature range is from -40 to 1100oC, but the pot seal is rated at only 200oC.
Assuming the pot seal is the point where the wire enters the probe, how can this only withstand 200oC when the probe is rated at 1100oC ?
We intend to drill a hole in the heating plate and fully insert the probe (pot seal will be out of the block), but still, I am sure that this part will reach more than 200oC-
Is my understanding correct? If so, how can we prevent the pot seal from reaching temps which exceeds 200oC ?
https://uk.rs-online.com/web/p/thermocouples/8471053?searchId=f4723c8d-98eb-49d3-b4b9-12fe4c8ea53a&gb=s
Logged
tooki
Super Contributor
Country:
Re: Thermocouple probe temperature range
Reply #1 on:
May 06, 2024, 06:44:35 pm »
Well, it’s conceivable to heat only the very tip of the probe. Stainless steel is a very poor conductor of heat (for a metal), so this is not an unusual situation.
However, that probably makes this probe a poor choice for your application.
Logged
jonpaul
Super Contributor
Country:
Reply #2 on:
May 07, 2024, 05:28:14 am »
check the Omega and other temp measurement probe sites.
All TC soecs, wells, etc avail for all apps and environments.
Excellet handbook as well.
https://www.omega.com/en-us/temperature-measurement/c/temperature-probes
Bon chance
Jon
Logged
Jean-Paul the Internet Dinosaur
perieanuo
Frequent Contributor
Country:
Reply #3 on:
May 07, 2024, 10:40:20 am »
Hi, in similar case I used threaded M3 thermocouple screwed into aluminum heating plate (well, 2 cylinder heating resistors were used to heat the plate). Just position your thermocouple in a good position.
If you wanna do it with your choice, use a wire terminal, those used with M3/M4 screws by pressing your thermocouple ending gently into the terminal, this will do too if you choose correctly his mounting spot and the force to keep it in the terminal at minimum needed.
https://www.tme.eu/ro/details/1-320551-3/terminale-izolate/te-connectivity/
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
