Well, yeah.
Many supervisor/reset ICs come in variants: different output polarity, OD or totem pole...
Just select one that has a totem pole output with inverted polarity, and drive a MOSFET with max VDS > 12V. Done.
The LTC2965 mentioned by David is interesting if PCB area is at a premium, but otherwise not sure it's worth it compared to the above solution. LTC2965 is not cheap.
