Links:
https://www.infineon.com/dgdl/Infineon-IPP60R022S7-DataSheet-v02_01-EN.pdf?fileId=5546d4626bb628d7016bc25d1085779dhttps://www.infineon.com/dgdl/Infineon-IPW60R024P7-DS-v02_00-EN.pdf?fileId=5546d462696dbf120169b48730044ab3Three things, I would guess:
1. dV/dt is a rating determined by how the junctions/layers are interconnected. For the MOSFET, turning on the parasitic BJT (drain-substrate-source) must be avoided, which can occur by capacitive coupling. The B-E junction of this BJT is effectively shorted out by a finite resistance (source/body spreading resistance), thus an RC differentiator is created, and a critical rising dV/dt can turn it on.
2. Diode dV/dt is the same effect, exacerbated by the residual free charges from body diode conduction (minority carriers). As charges clear the junction and it becomes depleted, the width of the depletion region -- thus its breakdown voltage -- gradually increases. In rectifiers, this is observed directly as the dV/dt slope (and corresponding turn-off losses) in inductive commutation. In MOSFETs, the free charges make the parasitic BJT more sensitive and thus the dV/dt limit is lower.
In either case, BJT turn-on incurs additional minority carriers, which take time to dissipate (like a diode reverse-recovery tail, or IGBT turn-off), and which can result in unstable current flow -- rapid breakdown and destruction. The breakdown mechanism is the same one which allows small BJTs to act as
pulse generators, but which only occurs at a single point (as far as I know) -- thus the entire junction capacitance of the device (plus any attached load, eventually*) discharges through a, perhaps nanometer sized point, quickly turning it into a crater.
*Since it'll take many nanoseconds for any load current to begin flowing to this magnitude, due to lead inductance.
The same effect applies to avalanche breakdown, and indeed we see this device has quite a low rating: I_AS = 3.8A, compared with 12.2A of the P7. (Which still isn't all that much, considering an older device like
IRFPS43N50K -- granted it has probably twice the die area, given the about double E_AS and Qg(tot) -- is rated for full load current at avalanche; beefy!)
Curiously, they claim a 9ns rise/fall time at 300V (inductive load) for the part, or 33kV/us. I'm not sure what distinction (if any) should be made, or is meaningful, for self-commutated versus externally-commutated operation. It does seem rather suspicious.
For more detail on dV/dt, see:
https://www.mouser.com/pdfdocs/Impacts_of_dv-dt_Rate.pdf3. The SuperJunction structure itself has capacitive losses. Perhaps this has been optimized as well for the device? I don't know how fine they're making these structures these days. It doesn't seem to have improved this much between the two, you're right.
SJ is... weird. I wrote this post a little back,
https://www.eevblog.com/forum/projects/superjunction-pulse-generator-(of-sorts)/msg4767362/#msg4767362apparently it can be so abrupt as to generate very sharp risetimes in otherwise innocuous (i.e. dis/charging with a large-value resistor) conditions, hence the headline figure in the post. It has a dielectric loss effect, which can be understood as the bulk resistance of the N/P pillars working in series with their capacitance, and so when the structure changes from fully depleted (high Vds, very low capacitance) to partially (low Vds, very high capacitance), charge has to rush in along those narrow pillars, acting in series with the sudden change in capacitance. At high frequencies (100s kHz), it manifests as dielectric loss.
