Author Topic: Inline resistor IC  (Read 763 times)
Offline Sangharsh SharmaTopic starter
  • Country: np
Inline resistor IC
« on: May 11, 2019, 09:26:51 am »
I am using seven segment displays for a project I'm involved in. I have to connect resistors to each pins of the IC and my circuit is already is very complex. So, this complicates things even more. I once saw in internet somewhere, a inline resistor IC , that has resistor connected inline inside t. So, basically it can be used as a substitute. I can't find the  IC anywhere. What's the name of that IC? Could anyone help me?
Offline sleemanj
  • Professional tightwad.
Re: Inline resistor IC
« Reply #1 on: May 11, 2019, 09:40:47 am »
You are looking for a resistor array, aka resistor network, they come in various packages, some look like ICs, some look like sideways smd resistors, some look like sil packages...
https://www.google.com/search?q=resistor+array&safe=off&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj_ubCxl5PiAhXEPo8KHcFDBFEQ_AUIDigB&biw=1680&bih=959
Offline Kalvin
  • Embedded SW/HW.
« Reply #2 on: May 11, 2019, 10:14:18 am »
Have you considered using SMD resistors, like 0805-size or 0603-size. They are cheap, easy to obtain, small yet quite easily solderable by hand, and they do not require drilling for the wires.
