Author Topic: Inline USB 2.0 switch for test automation – how to simulate clean disconnect/rec  (Read 314 times)
Offline mastupristiTopic starter
Hi all,
I'm working on a small USB-controlled inline device that sits between a USB host (typically a PC with a USB-A or USB-C port) and a USB device (either USB Micro-B or USB-C).
The goal is to simulate a USB cable disconnect/reconnect under software control — to trigger device re-enumeration, activate bootloaders, or perform power-cycle testing as part of automated QA.
The USB link is always USB 2.0, and devices may be either Full Speed or High Speed.
Use case
I work with different classes of devices:
  • A USB 2.0 device with a Micro-B connector, drawing minimal current, no negotiation involved
  • A USB 2.0 device with a USB-C connector that relies on current negotiation, e.g. it negotiate to draw 1.5 A
  • etc...
I would like to be able to disconnect/reconnect the device to the host in a controlled way. Just like a switch that behave exactly like a passive cable during normal operation, but simulate a physical detach/reattach event when controlled by a microcontroller (e.g., via GPIO).
In this scenario, the system should remain as transparent as possible and not interfere with expected power negotiation behavior, especially for USB-C devices.
“Active” components, such as hubs, could be used instead, but always with the ability to disconnect ports via software
Constraints
  • USB 2.0 only (no USB 3.x or USB PD involved)
  • Host is USB-A or USB-C
  • Device side may be USB-C or Micro-B
  • Some USB-C devices expect 1.5 A capability (maybe more in the future)
  • Devices may run at High Speed (480 Mbps), so any switching must be signal-integrity friendly
  • Simple, robust implementation preferred (ideally without requiring USB drivers or protocol stacks)
Conceptual block diagram
Here's the high-level idea:
The "switch block" might control VBUS, CC (for USB-C), and possibly D+/D− if needed.
Open questions
I'm evaluating a few possible approaches, and I’d love to hear feedback from others who’ve worked on similar USB tools:
  • What USB lines need to be switched to properly simulate a clean detach from the device’s perspective?
    • Is switching only VBUS enough?
    • Do I need to disconnect CC (for USB-C)?
    • Should D+/D− be switched as well for High Speed?
  • Is there a better approach using USB redrivers with enable/disable control?
  • Would a USB 2.0 hub IC (e.g. USB2412) with per-port power control be a better, more spec-compliant choice?
  • What kind of switches (analog/SPDT/SPST) are usable for CC or D+/D− in USB 2.0 High Speed?
  • Any other chip suggestions or reference designs?
I'm not looking for one specific solution — I'm open to advice on architecture, part selection, and general experience.
Has anyone here built something similar? Any thoughts are welcome.
Thanks in advance!
