Author Topic: KV7RF SMD Datasheet  (Read 1370 times)
Offline sdancer75Topic starter
  • Country: gr
KV7RF SMD Datasheet
« on: April 21, 2019, 11:00:42 am »
Can someone identify a 6-Pin IC SMD with the marking code KV7RF? Searching in Google I didn't find anything. Any help on this?
Offline DaJMasta
    • medpants.com
Re: KV7RF SMD Datasheet
« Reply #1 on: April 21, 2019, 05:46:15 pm »
Don't have a part number for you, but SMD codes aren't usually that long, maybe some subset of the code is what shows on the datasheet.  Definitely a switching converter, though, if you can ID the in/out voltage and the pinout, you may be able to make a good guess at a replacement, at least.
The following users thanked this post: sdancer75
Offline amyk
« Reply #2 on: April 21, 2019, 06:00:38 pm »
SY8089AAAC
Look at pictures from those who sell them to confirm.
  • Country: gr
« Reply #3 on: April 22, 2019, 10:39:43 am »
SY8089AAAC
It seems to be the same IC...     I will check this out!
Best Regards,
